Mplab Sim
Results 1 to 16 of 16
Thread: Mplab Sim
    Apr 2007
    Question Mplab Sim
    Hi everyone! Let me start by saying that I'm new to PIC, I have done some programing VB, C, C++, and some others. I have written a program in MCSP, it appears to compile fine. I then loaded the *.hex file in to MPLab and started the simulator with simulator logic analyzer, and stimulus. When if fire an input nothig changes, and it some times crashes, is there a trick to get it to work right? Or is there a better way of checking out a program before building the circut and programing a chip?
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    show us your code - otherwise the sky is the limit for guesses as to why you are having issues
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Apr 2007
    Exclamation Mp Sim
    this go in a car, it plays a sound track and flashes some leds with the sound track. It also lights the leds with the head lights and flashes them with the turn signals. there are two diffrent way it plays the soundtrack dependingon rather the car is running or not. I have to make the circut board for this as well so I need to know that this runs correctly so the PCB will work or if I need to change the PCB. That's where MPLAB SIM comes in, But I can't get it to work. I have till mid june to have everything complete and instaled in the car for a national show, that is design and make the PCB program the PIC and the sound track, put it all together and instal it. BTW I'm using a 16F628 chip.
    'Declared variables
    PLAYOUT var PORTA.0
    RESET VAR PORTA.1
    CAT_EYE_l VAR PORTA.2
    CAT_EYE_R VAR PORTA.3
    ARMED VAR PORTA.4
    ACC VAR PORTB.0
    LIGHTS VAR PORTB.1
    TURN_L VAR PORTB.2
    TURN_R VAR PORTB.3
    PIR VAR PORTB.4
    PUSH_BUTTON VAR PORTB.5
    WAITOUT VAR PORTB.7
    'DEFINE PORT DIRECTIONS & VALUES
    TRISA = %11111111
    TRISB = %11000000 'portb.6 and .7 out puts all others in put
    '///////set initial pin states/////////////////////////
    LOW PLAYOUT
    LOW RESET
    LOW CAT_EYE_L
    LOW CAT_EYE_R
    LOW ARMED
    HIGH WAITOUT
    '////////MAIN PROGRAM STARTS HERE//////////////
    Pause 30000
    LOW WAITOUT
    HIGH ARMED
    '///////MAIN LOOP STARTS HERE
    MAIN:
    IF ACC = 1 THEN
    GOSUB RUN
    GOSUB SHOW
    GOTO MAIN
    'RUN LOOP STARTS HERE
    RUN:
    IF LIGHTS = 1 THEN
    HIGH CAT_EYE_L
    HIGH CAT_EYE_R
    LOW CAT_EYE_L
    LOW CAT_EYE_R
    IF PUSH_BUTTON = 1 THEN
    GOSUB PLAY
    HIGH ARMED
    LOW WAITOUT
    GOSUB TURN
    'SHOW LOOP STARTS HERE
    SHOW:
    IF PIR = 1 THEN
    LOW ARMED
    HIGH WAITOUT
    GOSUB PLAY
    PAUSE 60000
    LOW WAITOUT
    HIGH ARMED
    'PLAY STARTS HERE
    PLAY:
    LOW ARMED
    HIGH WAITOUT
    HIGH CAT_EYE_L
    HIGH CAT_EYE_R
    PulsOut RESET,10
    Pause 100
    PulsOut PLAYOUT,10
    Pause 820
    LOW CAT_EYE_L
    LOW CAT_EYE_R
    Pause 50
    HIGH CAT_EYE_L
    HIGH CAT_EYE_R
    Pause 2550
    LOW CAT_EYE_L
    LOW CAT_EYE_R
    Pause 50
    HIGH CAT_EYE_L
    HIGH CAT_EYE_R
    Pause 5500
    LOW CAT_EYE_L
    LOW CAT_EYE_R
    'TURN STARTS HERE
    TURN:
    IF LIGHTS = 1 THEN
    IF TURN_L = 1 THEN
    LOW CAT_EYE_L
    HIGH CAT_EYE_L
    IF TURN_R = 1 THEN
    LOW CAT_EYE_R
    HIGH CAT_EYE_R
    IF TURN_L = 1 THEN
    HIGH CAT_EYE_L
    LOW CAT_EYE_L
    IF TURN_R = 1 THEN
    HIGH CAT_EYE_R
    LOW CAT_EYE_R
    Wink I/O salad ...
    The first thing I see is you have mixed inputs and outputs ...
    ex; if PIR = 1 then ... etc.etc. ... and PIR is declared as an output ( possible ... but really surprising here !!! )
    same for "lights" ...
    Begin by checking all your I/0 declares ... ( 0 for OUTPUT and 1 for Input = simple !!! )
    Apr 2007
    Question Mplab Sim
    That is " if pir is high then...", same with the lights "if lights high then...".
    Or have I done something wrong?
    Talking
    I've just tried to explain you you were reading your outputs instead of the inputs ...
    Of course, MPSIM has some trouble with that !!!
  1. MPLAB SIM timing vs Real life
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 17th July 2008, 17:32
  2. MPLab SIM question
    By presario1425 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2007, 22:22
  3. Linker/COFF debugging in MPLAB SIM
    By RichardBowser in forum mel PIC BASIC Pro
    Last Post: - 14th January 2007, 19:28
  4. Tracing code in MPLAB Sim
    By ErnieM in forum mel PIC BASIC Pro
    Last Post: - 8th August 2005, 17:00
  5. pause loop lockup with mplab sim
    By power67 in forum mel PIC BASIC Pro
    Last Post: - 12th February 2005, 14:10
