Mplab Sim
Results 1 to 16 of 16
Thread: Mplab Sim
    Apr 2007
    Question Mplab Sim
    Hi everyone! Let me start by saying that I'm new to PIC, I have done some programing VB, C, C++, and some others. I have written a program in MCSP, it appears to compile fine. I then loaded the *.hex file in to MPLab and started the simulator with simulator logic analyzer, and stimulus. When if fire an input nothig changes, and it some times crashes, is there a trick to get it to work right? Or is there a better way of checking out a program before building the circut and programing a chip?
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    show us your code - otherwise the sky is the limit for guesses as to why you are having issues
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Apr 2007
    Exclamation Mp Sim
    this go in a car, it plays a sound track and flashes some leds with the sound track. It also lights the leds with the head lights and flashes them with the turn signals. there are two diffrent way it plays the soundtrack dependingon rather the car is running or not. I have to make the circut board for this as well so I need to know that this runs correctly so the PCB will work or if I need to change the PCB. That's where MPLAB SIM comes in, But I can't get it to work. I have till mid june to have everything complete and instaled in the car for a national show, that is design and make the PCB program the PIC and the sound track, put it all together and instal it. BTW I'm using a 16F628 chip.
    'Declared variables
    PLAYOUT var PORTA.0
    RESET VAR PORTA.1
    CAT_EYE_l VAR PORTA.2
    CAT_EYE_R VAR PORTA.3
    ARMED VAR PORTA.4
    ACC VAR PORTB.0
    LIGHTS VAR PORTB.1
    TURN_L VAR PORTB.2
    TURN_R VAR PORTB.3
    PIR VAR PORTB.4
    PUSH_BUTTON VAR PORTB.5
    WAITOUT VAR PORTB.7
    'DEFINE PORT DIRECTIONS & VALUES
    TRISA = %11111111
    TRISB = %11000000 'portb.6 and .7 out puts all others in put
    '///////set initial pin states/////////////////////////
    LOW PLAYOUT
    LOW RESET
    LOW CAT_EYE_L
    LOW CAT_EYE_R
    LOW ARMED
    HIGH WAITOUT
    '////////MAIN PROGRAM STARTS HERE//////////////
    Pause 30000
    LOW WAITOUT
    HIGH ARMED
    '///////MAIN LOOP STARTS HERE
    MAIN:
    IF ACC = 1 THEN
    GOSUB RUN
    GOSUB SHOW
    GOTO MAIN
    'RUN LOOP STARTS HERE
    RUN:
    IF LIGHTS = 1 THEN
    HIGH CAT_EYE_L
    HIGH CAT_EYE_R
    LOW CAT_EYE_L
    LOW CAT_EYE_R
    IF PUSH_BUTTON = 1 THEN
    GOSUB PLAY
    HIGH ARMED
    LOW WAITOUT
    GOSUB TURN
    'SHOW LOOP STARTS HERE
    SHOW:
    IF PIR = 1 THEN
    LOW ARMED
    HIGH WAITOUT
    GOSUB PLAY
    PAUSE 60000
    LOW WAITOUT
    HIGH ARMED
    'PLAY STARTS HERE
    PLAY:
    LOW ARMED
    HIGH WAITOUT
    HIGH CAT_EYE_L
    HIGH CAT_EYE_R
    PulsOut RESET,10
    Pause 100
    PulsOut PLAYOUT,10
    Pause 820
    LOW CAT_EYE_L
    LOW CAT_EYE_R
    Pause 50
    HIGH CAT_EYE_L
    HIGH CAT_EYE_R
    Pause 2550
    LOW CAT_EYE_L
    LOW CAT_EYE_R
    Pause 50
    HIGH CAT_EYE_L
    HIGH CAT_EYE_R
    Pause 5500
    LOW CAT_EYE_L
    LOW CAT_EYE_R
    'TURN STARTS HERE
    TURN:
    IF LIGHTS = 1 THEN
    IF TURN_L = 1 THEN
    LOW CAT_EYE_L
    HIGH CAT_EYE_L
    IF TURN_R = 1 THEN
    LOW CAT_EYE_R
    HIGH CAT_EYE_R
    IF TURN_L = 1 THEN
    HIGH CAT_EYE_L
    LOW CAT_EYE_L
    IF TURN_R = 1 THEN
    HIGH CAT_EYE_R
    LOW CAT_EYE_R
    Wink I/O salad ...
    The first thing I see is you have mixed inputs and outputs ...
    ex; if PIR = 1 then ... etc.etc. ... and PIR is declared as an output ( possible ... but really surprising here !!! )
    same for "lights" ...
    Begin by checking all your I/0 declares ... ( 0 for OUTPUT and 1 for Input = simple !!! )
    Apr 2007
    Question Mplab Sim
    That is " if pir is high then...", same with the lights "if lights high then...".
    Or have I done something wrong?
    Talking
    I've just tried to explain you you were reading your outputs instead of the inputs ...
    Of course, MPSIM has some trouble with that !!!
    skimask's Avatar
    skimask Guest
    The HIGH and LOW commands automatically set the respective pins to outputs....but the few input statement still won't work....
    Also, PIR is a named register on PICs. You might not want to use that name for a variable. Might mess you up in the future. Same with RESET (could be confused with the MCLR function somewhere sometime) and ACC (some might confuse that with Accumulator).
    Wink Cool, cool ...
    Hi, Skimask
    the "reserved word" is PIR1 ... then, no Pb with PIR.
    Now look at output initialisation :
    - the named outputs are declared as inputs in the TRIS ... and vice-versa.
    skimask's Avatar
    skimask Guest
    Hi, Skimask
    PIR - just pointing the PIR out as well as the others for future reference, something that might cause a problem in the future.
    I/O - yep, noticed that right away, but you got to it first
    Talking
    Hi, Skimask
    You know what ???
    I really DO HATE "tuning" ....
    LOL
    Feb 2003
    Smile I/O Salad indeed ...
    More to try
    1)Turn the Comparators OFF to get PORTA to work as intended
    2)
    TRISA = %11111111
    You set all of PORTA inputs here but make them outputs in your code
    3)
    You got the comment backwards (0=output, 1 = Input)
    4)Remember RA4 is open drain so it needs a pullup on your real circuit
    5)
    Oh, and it it were me, I would start with this and make this work with the Simulator
    TRISB=1
    MAIN:
    IF PORTB.0 = 1 then
    	PORTB.1=1
    	PORTB.1=0
    GOTO MAIN
    Post back after you try some of these
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Apr 2007
    Question Mplab Sim
    I have made these changes:
    1 trisa is now %00000000
    2 trisb is now %00111111
    3 pir is now pirin this should reduse any confusition.
    Would this be correct? I will later change armed from porta.4 to portb.6 to not have to use a pull up resister and reduse current draw to a min.
    skimask's Avatar
    skimask Guest
    Question
    I think I missed something in the translation...
    Apr 2007
    Cool Mplab Sim
    Now that i have the input output thing fixed, I have determined that the program is hanging in the "pause" statments, is there a trick to get thes to work? I changed them to "pauseus" and everything seem to be perfict. Thank you to all that help this noobe.
    Wink The show might go on, then ...
    Quote Originally Posted by steelman View Post
    your answer is in the FAQs ... MPSIM is a simulator, yes ... but not a REAL TIME simulator !!!
    See MPSIM Help section will show you that ... in official details.
    Time to understand the difference between simulated world and real World ... LOL !
    skimask's Avatar
    skimask Guest
    Is it actually hanging up in the pause statement in the sim or is MPSIM just simulating them really slowly? Try changing the pause statements in the program to something a lot lower than you have and see what happens.
  1. MPLAB SIM timing vs Real life
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 17th July 2008, 17:32
  2. MPLab SIM question
    By presario1425 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2007, 22:22
  3. Linker/COFF debugging in MPLAB SIM
    By RichardBowser in forum mel PIC BASIC Pro
    Last Post: - 14th January 2007, 19:28
  4. Tracing code in MPLAB Sim
    By ErnieM in forum mel PIC BASIC Pro
    Last Post: - 8th August 2005, 17:00
  5. pause loop lockup with mplab sim
    By power67 in forum mel PIC BASIC Pro
    Last Post: - 12th February 2005, 14:10
