ADC_IN statement
Results 1 to 9 of 9
    Jan 2006
    New Hampshire, USA
    Default ADC_IN statement
    I am elated that my IF - Then compiles OK, but I am trying to use the A/D converter and I get a "syntax error" on the ADC_IN statement. I looks just like the example in the manual to me. Here is my program:
    REM DEVICE = 12F675
    REM USE INTERNAL OSCILLATOR, OUTPUT IS ON GP4 (PIN3)
    REM CONFIGURATION: INTOSC CLOCKOUT, WDT DISABLED, PWR UP ENABLED,
    'MCLR = INPUT PIN,BROWN OUT DISABLED, NO PROTECTION
    REM CLOCK OUT ON PIN 3 (GP4)
    REM CHARGER SWITCH ON PIN 7 (GP0)
    REM A/D INPUT ON PIN 4 (GP3)
    REM GREEN LED ON PIN 2 (GP5)
    ADCON0 = %00001101 'LEFT JUSTIFIED, VDD REF, CHANNEL 3, A/D INITIALLY OFF
    ANSEL = %01001000 'CLOCK IS FOSC/4, INPUT TO GP3
    TRISIO = 0 'ALL OUTPUTS EXCEPT GP3
    GPIO = 0 'ALL OUTPUTS INITIALLY LOW
    DEFINE OSCCAL_1K 1 'SAVES OSCILLATOR CALIBRATION
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 5 'INTOSC_CLOCKOUT?
    DEFINE ADC_SAMPLESUS 50 '50 MICROSECONDS SAMPLE TIME
    VOLT VAR WORD
    OLDVOLT VAR WORD
    GREEN VAR GPIO.5
    SWITCH VAR GPIO.0
    START:
    LOW SWITCH 'TURNS ON CHARGER
    PAUSE 60000 'DELAY 1 MINUTE
    HIGH SWITCH 'TURN OFF CHARGER
    ADC_IN 3,VOLT 'SAMPLE CHANNEL 3, STORE BATTERY VOLTAGE
    IF VOLT < OLDVOLT THEN
    STOPCHG
    OLDVOLT = VOLT
    GOTO START
    STOPCHG:
    HIGH GREEN
    STOP
    Talking Clean your glasses ...
    Hi Russ
    Just write "ADCIN" ( no underscore ...)
    << loop: ADCIN 0, adval ' Read channel 0 to adval >>
    If this is a NiMH charger controller type thing, there's no reason to shut off the charger to check your battery voltage. But, instead of taking a single reading and comparing that to your old reading, I'd take a load of readings over a minute, add them up, and then see if the new 'summed reading' is less than the old 'summed reading'. That way, any voltage drops due to mains power fluctuations, ripple in the power supply, etc. should be compensated for. Try this instead:
    adcon0=$d:ansel=$48:trisio=0:gpio=0
    DEFINE ADC_BITS 10
    volt var word : oldvolt var word:green var gpio.5:switch var gpio.0:summedvolts var word : oldsummedvolts var word:sumcounter var byte:fudgefactor var byte:fudgefactor=100:low switch
    START:
    pause 60000:for sumcounter=1 to 64:adcin 3,volt:summedvolts=summedvolts+volt:next sumcounter:if ( summedvolts - fudgefactor ) < oldsummedvolts then stopchg
    oldsummedvolts=summedvolts:summedvolts=0:goto start
    STOPCHG:
    high green:stop
    Another problem the original is that there is no 'slop' built into it. One ADCIN count less, and the charger stops. That's why I added the 'fudgefactor' to it.
    STOPCHG
    should be
    IF VOLT < OLDVOLT THEN STOPCHG
    Jan 2006
    New Hampshire, USA
    Thanks, Alain, it is working now.
    Steve: you are right, my code didn't work, but yours doesn't either! What works is:
    IF volt "<" oldvolt THEN
    GOTO stopchg
    Thanks, all.
    Russ
    <table><tr><td></td><td>
    well unless we don't use the same compiler, it must return a syntax error as well
    </td></tr></table>
    If something=something_else then Label
    is the same thing as
        goto Label
    At least here... so that's weird.
    the only valid syntax i know is
    DEFINE ADC_SAMPLEUS 50
    Yeah, it doesn't return any syntax error... it's just ignored. Fortunately there's some default value
    pbppic14.lib
    ;* Default Adcin values                                         *
        ifndef ADC_BITS		; ADC number of bits
    ADC_BITS EQU 8
        ifndef ADC_CLOCK		; ADC clock source = rc
    ADC_CLOCK EQU 3
        ifndef ADC_SAMPLEUS		; ADC sample time in microseconds
    ADC_SAMPLEUS EQU 50
    Thumbs down
    Hi, Skimask
    " If this is a NiMH charger controller type thing, there's no reason to shut off the charger to check your battery voltage"
    You're TOTALLY WRONG !!!
    just look at ALL NiMh and NiCd "reflex" chargers ... why stop charging when sampling voltage then ... ???
    good question !!!
  1. newbe: IF..THEN statement
    By ShawnB in forum mel PIC BASIC Pro
    Last Post: - 11th November 2009, 15:07
  2. 16F883 and Problems with HIGH statement
    By aaanekre in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 02:09
  3. END Statement
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 9th November 2008, 15:48
  4. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  5. getting around the basic IF - THEN statement
    By dw_pic in forum mel PIC BASIC Pro
    Last Post: - 7th February 2006, 15:10
