Microcontroller with 2 way paging application problem
Results 1 to 31 of 31
Threaded View
  1. #23
    Mar 2007
    I find that sometimes when I connect by wire it doesn't work. Sometimes my wireless connection works if I first connect the wire remove it and then I reconnect my wireless connection it works again. I'm not sure if the serout is not working correctly or the serin is not working correctly.
    Receiver (434)
    'IEEE encoding
    Include "Modedefs.bas"
    'trisb = 0
    s var byte : B0 var bit : B1 var bit : encode var byte: encode2 var byte 's is byte to be encoded, B0 and B1 is byte for the hardwired address (first two bits)
    counter var byte : ct55 var byte: counter2 var byte'counter is the amt of bit which is 4 in the input is byte and ct55 is to count the $55 byte
    'counter2 counts the number of times acknowledge light blinks.
    encode1 var byte : action var byte : alert var byte : action2 var byte: B0=0 : B1=1: counter3 var byte
    'encode1 byte sized variable that holds encoded byte s, alert variable, action variable used for trakcing mode, action2 used for track and find mode, B0 and B1 are the hardwired address
    c var byte: d var byte: e var byte: s=0: encode1=0: c=0: d=0: e=0: action =0: action2=0: encode2=0
    'c (track mode), d (track and find) and e(address) are bytes; initialize all values to zero
    'encode holds the encoded variable after ack made in track mode, encode2 holds the encoded variable after ack made in track and find mode.
    Clr:
    s=0: encode1=0: c=0: d=0: e=0: action =0: action2=0: encode2=0 'initialize variables to zero
    Maina:
    ct55 = 0 'counter for $55 is zero
    Wait55:
    serin PORTB.0, n2400, encode1 'take in data at pin 0 and place in encoded1
    If encode1 = $55 Then
    ct55 = ct55 + 1 '$55 read, increase ct55 by 1
    If ct55 = 4 Then goto Waitaa 'if $55 occurs 4 times in a row check for $aa
    Else
    goto maina 'if not $55, reset counter at main and restart
    Endif
    goto wait55
    Waitaa:
    serin PORTB.0, n2400, encode1 'wait for $aa
    If encode1 <> $aa Then goto Maina 'restart, incorrect leader bit
    serin PORTB.0, n2400, encode1 : 'serout PORTB.4, n2400, [encode1] take in from Port B Pin 0 to encoded1 output to Port B Pin 3 contents in encode1
    write 0,encode1 'write to EEPROM Location 0
    'High 2 'High on Port B Pin 2
    'Pause 2000 'Pause
    'Low 2 'Low on Port B Pin 2
    'Decoding
    For counter=0 to 3:s.0[counter]=encode1.0[counter*2]:Next counter 'Go through counter place bit 0, 2, 4, 6 in s
    'serout PORTB.3, n2400, [s] 'Ouptut decoded message s to Port B Pin 3
    write 1, s 'write to EEPROM Location 1
    'High 6 'High on Port B Pin 6
    'Pause 2000 'Pause
    'Low 6 'Low on Port B Pin 6
    e = s 'Copy s to byte e
    If ((e.3=B0) and (e.2=B1)) Then 'Check if address matches (first two bits)
    goto L3 'if it matches go to L3
    Else
    write 2,s 'Write to EEPROM Location 2
    High 3 'High on Port B Pin 2
    Pause 2000 'Pause
    Low 3 'Low on Port B Pin 2
    goto Clr
    Endif
    L3:
    'Tracking mode (mode is based on last two bits)
    c=s: d=s: 'Copy s to byte c and s to byte d
    If ((c.1=0) and (c.0=0)) Then
    action=s: 'Copy s to action byte
    action.1=1'set the third bit of action1 to 1 and send it back
    'alert = 0: 'set alert to 0
    write 3, action 'Write to EEPROM Location 3
    High 6 'High on Port B in 1
    Pause 2000 'Pause
    Low 6 'Low on Port B in 1
    'Manchester Encoding
    For counter = 0 to 3
    If action.0[counter]=0 Then
    encode.0[counter*2]=0 : encode.0[counter*2+1]=1 'If it is a zero make the first bit 0 and second bit 1
    Else
    encode.0[counter*2]=1 : encode.0[counter*2+1]=0 'If not then make first bit 1 and second bit 0
    EndIf
    Next counter :
    write 8, encode 'Write encode to EEPROM Location 8
    Low 4 'Low on Port B Pin 4
    For counter = 0 to 5 'Blink LED 5 times
    Pause 400 'Pause
    High 4 'High on Port B Pin 4
    Pause 400 'Pause
    Next counter 'Back to beginning of loop
    For counter3 = 0 to 50 'Send three times
    serout PORTB.2, n2400, [ $55, $55, $55, $55, $55, $55, $55, $55, $55, $aa , encode ] 'send out preamble and encode on PORTB pin 2
    Next counter3 'Next number
    goto Clr
    Endif
    'Tracking and Finding mode (is based on last two bits)
    If ((d.1=0) and (d.0=1)) Then
    action2=s 'Copy s to action2 byte
    action2.1=1 'set the third bit of action2 to 1 and send back
    'alert=1
    write 4, action2 'Write to EEPROM Location 4
    High 5 'High on Port B Pin 4
    Pause 2000 'Pause
    Low 5 'Low on Port B Pin 4
    If action2.0[counter]=0 Then
    encode2.0[counter*2]=0 : encode2.0[counter*2+1]=1 'If it is a zero make the first bit 0 and second bit 1
    Else
    encode2.0[counter*2]=1 : encode2.0[counter*2+1]=0 'If not then make first bit 1 and second bit 0
    EndIf
    Next counter :
    'serout PORTB.2, n2400, [ $55 , $55 ,$55, $55, $55, $aa , encode2 ] 'send out preamble and code to Port B Pin 2
    write 9, encode2 'Write encode2 to EEPROM Location 9
    For counter2 = 0 to 5 'Blink LED 50 times
    Pause 400 'Pause
    Pause 400 'Pause
    Next counter2 'Back to beginning of loop
    Low 1 'Low on Port B Pin 4
    For counter = 0 to 10 'Blink LED 50 times
    Pause 400 'Pause
    High 1 'High on Port B Pin 1
    Pause 400 'Pause
    Low 1 'Low on Port B Pin 1
    Next counter: 'Back to beginning of loop
    For counter3 = 0 to 50 'Send data times
    serout PORTB.2, n2400, [ $55 , $55 ,$55, $55, $55, $55, $55, $55, $55, $aa , encode2 ] 'send out preamble and encode on PORTB pin 2
    goto Clr
    Endif
    Receiver (315)
    'IEEE encoding
    'trisb = 0
    s var byte : B0 var bit : B1 var bit : 's is byte to be encoded, B0 and B1 is byte for the hardwired address (first two bits)
    counter var byte : ct55 var byte: 'counter is the amt of bit which is 4 in the input is byte and ct55 is to count the $55 byte
    encode1 var byte : B0=0 : B1=1
    'encode1 byte sized variable that holds encoded byte s, B0 and B1 are the hardwired address
    e var byte: s=0: encode1=0:e=0
    ' e are bytes; initialize s, encode1, and e values to zero
    'encode1 holds the encoded variable received.
    Clr:
    s=0: encode1=0: e=0: 'encode2=0 'initialize variables to zero
    Maina:
    Wait55:
    Else
    Endif
    goto wait55
    Waitaa:
    High 7 'High on Port B Pin 7
    Pause 2000 'Pause
    Low 7 'Low on Port B Pin 7
    'Decoding
    Pause 2000 'Pause
    e=s
    If ((e.1==1)) Then 'Acknowledgment received because third bit is 1
    goto L4 'Jump to L4
    Else
    Pause 2000 'Pause
    goto Clr
    Endif
    L4:
    write 3, e 'Write to EEPROM Location 3
    High 1 'High on Port B in 1
    Pause 2000 'Pause
    Low 1 'Low on Port B in 1
    serout PORTB.3, n2400, [e.3] 'send out first bit from PORTB Pin 3
    serout PORTB.4, n2400, [e.2] 'send out second bit from PORTB Pin 4
    goto Clr
  1. PIC KIT 2 writing problem ?
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2010, 13:59
  2. Unusual Interrupts Application Problem
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 12:55
  3. Replies: 7
    Last Post: - 15th December 2008, 06:18
  4. PWM Problem
    By cihhan in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 19:43
  5. Replies: 18
    Last Post: - 24th January 2008, 23:44
