EasyHID max usb buffer size
Results 1 to 5 of 5
    Apr 2007
    Default EasyHID max usb buffer size
    Hey, I've got everything working with the pic 18f2550 to be recognized as a usb hid device. I'm sending accelerometer data and push button data to the pc using polling.
    I just wanted to know how to increase the data buffer. Easyhid configures the default buffer size to be an array of size 8 "USBBufferOut Var Byte[8]". Is there a way to change the buffer size to 11, or does this exceedthe max buffer size for HID devices?
    Quote Originally Posted by jizyjuice View Post
    Have you tried: USBBufferOut Var Byte[11]? Or search on something like 'usb buffer size'.
    I came up with:
    USBBufferSizeMax con 8 ' maximum buffer size
    USBBufferSizeTX con 8 ' input
    USBBufferSizeRX con 8 ' output
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    Looks to me like you change the 8 to an 11 and you're done.
    The search tool works great. But it's only great if you use it.
    The Input and Output report (buffer) sizes are set on the 3rd screen (Configuration Details) of EasyHID.
    You can have a max of 64 bytes.
    Apr 2007
    Oh cool, thanks. Yeah I tried to set the usbbuffer var byte 11, but that didnt work and would just never send any data to the pc.
    May 2007
    why don't just set buffer to 64 (max)? is there a drawback?
    "Beethoven had his critics too, see if you can name 3 of them"
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  3. Speed of USB EasyHID and Time problem
    By sjohansson in forum USB
    Last Post: - 18th January 2007, 23:21
  4. EasyHID and buffer entry 0
    By Demon in forum USB
    Last Post: - 19th August 2006, 20:34
  5. USB Interface using PIC
    Last Post: - 22nd May 2006, 17:04
