Ahh, well the TMR registers are like any other register in the PIC so you can read/write to/from them as you would with any other register. So to set the TMR0 registers to 0 (assuming a 16 bit TMR0 here):
MyCount var WORD		'This is my counter...
TMR0L = 0			'Reset lower byte
TMR0H = 0			'Reset hogher byte
Start:
  MyCount.HighByte = TMR0H	'Get high byte of counter
  MyCount.LowByte = TMR0L	'Get low byte of counter
  LCDOUT $FE,1,#MyCount		'Display it
  Pause 100
Goto Start
To PRESET it you write whatever value you wish to the two registers:
TMR0H = 3        'Preset TMR0 to 878....
TMR0L = 110     ' ( 3 * 256 + 110 )
That's really all there is to it. Well, one more thing. When reading the two TMR registers in the way shown above there is a slight chance the lower byte rolls over in the time between reading TMR0H and TMR0L. To come around that problem you can either enable 16bits read/writes (on PICs that supports it) or read the high byte two times, like:
MyCount VAR WORD
Temp var byte
Temp = TMR0H			'Get high byte again
IF Temp <> MyCount.HighByte then  'Do a fresh read
EndIf
HTH
/Henrik Olsson.
