I'm sorry but I'm not quite sure what the problem is...?
You can use TMR0 AND TMR1 as counters at the same time. OR you can use TMR0 AND TMR3 as counters at the same time. BUT you can NOT use TMR1 AND TMR3 as counters at the same time since they both share the same clock-pin (pin 15 on the 40-pin DIP package)
If this doesn't help please explain what the problem is , if you can.
/Henrik Olsson.
