HI2CREAD and HI2CWRITE
Results 1 to 18 of 18
    In theory it's possible... on the down side, i'm not sure Microchip always use the same naming convention between all their PICs... not surprised at all if not. But yes ... possible.
    Some "HiJack" method? Possible too... 'till now the user will need to manually modify the PBP library
    HI2CREAD and HI2CWRITE? Why stop there? What about ...
    SPI Master
    SPI Slave
    I2C Master
    I2C Multi-Master
    I2C Slave
    If you want to support the SSP modules, you should support the Whole Module.
    And both kinds ... SSP/MSSP.
    Yup, i agree, AND for ALL supported PIC in the list. Here comes the fun to check with >500 datasheets
    ... fun to check with >500 datasheets
    Don't forget the errata sheets that go with each datasheet.
    Seems to be a lot of SSP issues in the errata.
    You'd think they'd have that down by now.
    And once you're done...
    Q:Sir... why it's not working on a ABC but works on a XYZ which are pin2pin compatible
    A:Which Silicon version do you have, it's working here with x, y, z version
    Q:Silicone version? WTF? I use a JDM programmer, Vista, everything is properly wired with "crocodile jumpers"
    Mar 2006
    Talking Hardware Mssp
    PDS has everything running on Hardware MSSP PBP developers please implement them!!! acting like Motorola "One hit wonder" mongers
    Sep 2005
    Campbell, CA
    I'm among the group that wants HI2CREAD/HI2WRITE. The WRITE isn't so important, but the HI2CREAD would certainly make an interrupt-driven slave much easier.
    Charles Linquist
    Sep 2005
    Campbell, CA
    I should add that my previous statement assumes that SLAVE modes were added to the HI2CREAD/HI2CWRITE commands.
    And to make things easier - why not just concentrate on 18F parts? There isn't much of a cost differential anymore.
    Charles Linquist
    Mar 2005
    CROATIA
    Talking
    ye, i have to asemble mmc/sd card reader--> i2c writer with high bandwith...
    this is not posible with soft i2c, there is some intention to use hw_i2c with
    pbp (i saw example on the inet (try to google)) but if pbp put keyword like
    hserout, this should be best option, on other hand, if some magican like
    Darrel Taylor or other good hardcoderz write some how-to or entire macro
    for as halfprogramerz, so we can eassy implement hi2c(400Khz or faster) in
    our projects...
