IF...THEN won't let numbers to be summed
Results 1 to 15 of 15
    Feb 2005
    Kolkata-India
    Talking I changed my mind
    I wrote the original thread counting on my past experience but then again I didn't try out flotul's structure. May be I will trying peeping the compiled hex and find out if it does carry out a conditional check on ":"So did not want to confuse readers and edited. Your windows is working fine as the doors
    Sougata
    Jan 2006
    Istanbul
    A little suggestion:
    What about a Pause or a kind of bounce killing?
    Something like,
    IF MEM_l = 2  THEN
       WHILE MEM_l = 2 : WEND
       speed = speed + 1
    OR
    IF MEM_l = 2  THEN
       PAUSE 100
       speed = speed + 1
    Speed increases so fast that it goes crazy!
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    The manual and Flotu imply that:
    if mem_l = 2  then speed = speed + 1 : gosub game_speed
    is equivalent to
    if mem_l = 2  then
    	speed = speed + 1
    	gosub game_speed
    Flotu,
    does pbtn = 9 if no button is pushed? If it does then your code is doing what you told it to do - update speed each time through the loop while waiting for the button to be pushed whenever mem_1 is 2,3,4, or 5. See below
    MAIN:
        gosub READ_BTNS
        if pbtn < 4 and Ctr_L <= mem_l then
          'lots of stuff here removed for readability (see his  post #1)
      if mem_l = 3  then speed = speed + 1 : gosub game_speed
      if mem_l = 4  then speed = speed + 1 : gosub game_speed
      if mem_l = 5  then speed = speed + 1 : gosub game_speed
        value = value + 1           'To change the "seed" for random #
        Goto MAIN
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    SWITZERLAND (french speaking)
    Default Wow!!
    Thank you for all your remarks.
    The END statement was there only for testing purpose; I'm going to remove it.
    Yes, Pbtn=9 if no button is pressed.
    Well Paul, I think you have found the problem.
    Regarding the "IF xxxx THEN yyyy : zzzz", I thought that the "zzzz" would be executed ONLY when the IF statement is true. This is why I wrote it after each IF statement (didn't check this out now - will do this in a few minutes).
    I'll come back asap.
    Roger
    Thumbs up Bravo!
    I moved my four IF statements to the "correct place" in my loop and everything goes fine now.
    I admit, while searching for hours in the wrong direction, I've lost the overview of the program's cycle.
    So let me thank all of you one more time.
    I'm finishing some cleanups and port it to a PIC12F683 (it's my first SMD project...).
    Finally, I'll end this thread by attaching the ultimate code.
    Roger
    Default Here is the final result
    Hello,
    I've had lots of help from many of you so I share my code for this SIMON game.
    I wanted to make a hand-held SMD version of this game with 3 lifes and a level counter.
    Start the game on speed-level 1 by pressing button n°1 (most left) and, respectively, press button n°4 to start on speed-level 4.
    When you miss, the leds flash for the numbers of remaining lifes.
    After you have used your 3 lifes, all leds flash 3 times and then you can read your score: most-right led counts the Units, second led starting from right counts Tens.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1534&stc=1&d=117656874 5">
    Roger
    Neat PCB job! well done.
  1. Replies: 4
    Last Post: - 15th April 2009, 02:54
  2. Maths - Summing small numbers with decimals
    Last Post: - 22nd March 2008, 20:21
  3. Working with 3 byte numbers
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 26th July 2007, 23:59
  4. Splitting numbers and recombining them(EEPROM Error)
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2007, 07:40
  5. Returning whole numbers for DS1820?
    Last Post: - 12th February 2007, 13:15
