IF...THEN won't let numbers to be summed
Results 1 to 15 of 15
    SWITZERLAND (french speaking)
    Default IF...THEN won't let numbers to be summed
    Hello,
    I can't find out why this doesn't work:
    if mem_l = 2 then speed = speed + 1 : gosub game_speed
    while this does:
    if mem_l = 2 then speed =  1 : gosub game_speed
    According to the PBP Compiler's manual, both syntax look okay.
    When I run my prog with the second example, my Speed VAR will go crazy and show up numbers between 50 and 240(?). Speed is declared as VAR Byte and set to "0" at beginning of prog.
    I've attached my code (the concerned lines are labeled 'Set game speed according to level).
    Any help is appreciated.
    Roger
    Hello,
    while this does:
    You can't have a 'colon' in a single line if/then statement. You have to split it up, like this:
    If mem_1 = 2 then
    speed = speed + 1
    gosub game_speed
    EndIf
    or
    If mem_1 = 2 then
    EndIf
    I don't think the manual says it specifically, but that's the way it is.
    Default ?
    Hi skimask,
    Thanks for the help. I'm in the office now and I'm not sure about this anymore but I think I have tried what you suggest already and didn't work too.
    Nevertheless, I'll try again tonight (I'm in the office now).
    BTW, this is an example one can find in the COMPILER's manual (confusing):
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1533&stc=1&d=117644278 8">
    I've used this syntax many times before and never had trouble.
    Roger
    That non-optional ENDIF to complete the structure might have something to do with it?
    I do not see it in your code.
    Don't know why one works and the other doesn't.
    I just stick with what does work...
    I know, no help, but it's the facts...
    Also, I just looked thru your code.
    There's an END statement in the middle before GAME_SPEED.
    You probably don't want that in there.
    And a couple of your for/next statements, you don't specifically tell PBP which variable you are 'next'ing with your 'for'.
    Might help, might not...
    The second example in the first post does not work correctly.
    Look at this from the posted code.
        if mem_l = 3  then speed = 2 : gosub game_speed
        if mem_l = 4  then speed = 3 : gosub game_speed
        if mem_l = 5  then speed = 4 : gosub game_speed
    ''    if mem_l = 2  then speed = speed + 1 : gosub game_speed
    ''    if mem_l = 3  then speed = speed + 1 : gosub game_speed
    ''    if mem_l = 4  then speed = speed + 1 : gosub game_speed
    ''    if mem_l = 5  then speed = speed + 1 : gosub game_speed
        value = value + 1           'To change the "seed" for random #
        Goto MAIN
    Do you see a problem?
    Feb 2005
    Kolkata-India
    Wink Does this makes sense
    IF MEM_1 = 2 THEN SPEED = 1 : GOSUB SOMETHING
    is equivalent to
    GOSUB SOMETHING
    or
    IF MEM_1 = 2 THEN
    SPEED = 1
    GOSUB SOMETHING
    Sougata
  1. Replies: 4
    Last Post: - 15th April 2009, 02:54
  2. Maths - Summing small numbers with decimals
    Last Post: - 22nd March 2008, 20:21
  3. Working with 3 byte numbers
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 26th July 2007, 23:59
  4. Splitting numbers and recombining them(EEPROM Error)
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2007, 07:40
  5. Returning whole numbers for DS1820?
    Last Post: - 12th February 2007, 13:15
