some project for GLCD
Results 1 to 5 of 5
    Tehran, Iran
    Default some project for GLCD
    hi
    recently i have purchased a Graphical LCD, labeled "CGM12864B". it uses HD61202 controller (that is similar to ks0108).
    i want to drive this module with "PicBasic PRO" and i need some simple program and its schematic. also i see http://www.compsys1.com/workbench , but i need another project. (very simple project.)
    thankfully, Mostafa
    Quote Originally Posted by Mostafa View Post
    hi
    thankfully, Mostafa
    Print your name on the screen...
    Tehran, Iran
    i need pbp codes. do you have?
    best regards.
    Mar 2005
    Iowa, USA
    Might want to digest the code at compsys before begging for free code. Here's a helper link.
    http://www.picbasic.co.uk/forum/showthread.php?t=4460
    Maybe if you ask SlotH nicely, he'll post his code on the forum since his site seems to be down. But honsestly... go through the code example you already have.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    best regards.
    I've got all sorts of PBP code, just none for your particular application (which I don't know what you're trying to do) or for your PIC (because I don't know what you specific application is) or for the clock speed you plan on running your PIC at (because you didn't specify), or for that LCD (which I don't use).
    Last Post: - 8th March 2010, 21:58
  2. A Temperature & Humidity Data Recorder Project
    Last Post: - 9th July 2008, 19:47
  3. paying project i need done
    By n1cod3mus in forum General
    Last Post: - 13th October 2007, 06:58
  4. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
  5. A category for Project Ideas
    By Pic_User in forum Forum Requests
    Last Post: - 23rd June 2006, 08:29
