row -> col and col -> row
Results 1 to 6 of 6
    Jun 2006
    Default row -> col and col -> row
    I have the below code and work.
    But ,when i push the number 4 show 3 , when i push the number 7 show 3 , when i push the number 2 show 4
    when i push the number 3 show 7
    How to make the row -> col and col -> row to show right;
        Col VAR BYTE                 ' Keypad column
        Row VAR BYTE                 ' Keypad row
        Key VAR BYTE                 ' Key value
        Lcdout $fe, 1, "Press any key"          ' Display sign on message
    Loop:
        Gosub getkey                            ' Get a key from the keypad
        Lcdout $fe,1, #key
        goto loop
    GetKey:
        PAUSE 50                                ' Debounce key-input
    GetKeyu:                                    ' Wait for all keys up
        PORTB = 0                               ' All output-pins low
        TRISB = $f0                             ' Bottom 4-pins out, top 4-pins in
        IF ((PORTB >> 4) != $f) THEN getkeyu    ' If keys down, loop
    GetKeyp:                                    ' Wait for keypress
        FOR col = 0 TO 3                        ' 4 rows in keypad
        TRISB = (DCD col) ^ $ff                 ' Set one row pin to output
        row = PORTB >> 4                        ' Read columns
        IF row != $f THEN gotkey                ' If any keydown, exit
        NEXT col
        GOTO getkeyp                            ' No keys down, go look again
    GotKey:                                     ' Change row and column to key number 1 - 16
        key = (col * 4) + (NCD (row ^ $f))
        RETURN                                  ' Subroutine over
    Quote Originally Posted by savnik View Post
    SWAP col,row
    Jun 2006
    SWAP col,row
    I swap col with row with no succes
    Maybe do a search on 'matrix keypad'
    This is how I read a 16 matrix membrane switch. All horizonal rows connected to PORTC 1,2,3,4 outputs. All vertical columns connected to PORTB 1,2,3,4 inputs held high by resistor network. This example just shows eight readings:
    PORTC = 255 'MAKE SURE ALL OUTPUTS ARE HIGH
    START:
    LOW PORTC.1
    PAUSE 1
    IF PORTB.1 = 0 THEN ONE
    IF PORTB.2 = 0 THEN TWO
    IF PORTB.3 = 0 THEN THREE
    IF PORTB.4 = 0 THEN FOUR
    HIGH PORTC.1
    PAUSE 1
    LOW PORTC.2
    PAUSE 1
    IF PORTB.1 = 0 THEN FIVE
    IF PORTB.2 = 0 THEN SIX
    IF PORTB.3 = 0 THEN SEVEN
    IF PORTB.4 = 0 THEN EIGHT
    HIGH PORTC.2
    Pauses are added to slow down the process. Without them we experienced intermittant problems (probably from capacitance in the membrane switch). Hope this helps.
  1. keypad 4x3
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 15th July 2009, 07:34
  2. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 02:52
  3. cant get my Lcd to work using Pic18f452
    By civicgundam in forum General
    Last Post: - 7th October 2007, 01:13
