convert the numbers to word
Results 1 to 14 of 14
    Jun 2006
    Default convert the numbers to word
    getword:
        for x = 0 to 3
        Gosub getkey                ' Get a key from the keypad
        lcdout I,Line2 + x,#key     ' Display ASCII key number
        next
    I have a keypad and show the key on LCD if a button pressed.
    Like this : 2438
    How i can convert the numbers 2438 as a variable(word 2.438)
    Quote Originally Posted by savnik View Post
    getword:
        for x = 0 to 3
        next
    Like this : 2438
    http://www.picbasic.co.uk/forum/showthread.php?t=6050
    Posts #3 and #5
    Jun 2006
    I don't want this
    If i press the button 2 i take 2 , after i press the button 4 and take 4 ,etc
    3 and 8
    How to take a word with this number : 2 and 4 and 3 and 8
    like this: value = 2438
    I don't this
    3 and 8
    I guess there's a bit of a language barrier going on here. I don't really get what you're trying to say...
    Apr 2006
    New Hampshire USA
    Smile My guess
    Hi savnik,
    See if I read you correctly.
    You want the user to be able to press a series of buttons, on your keypad. You would like the PIC to take this series of separate button values and “string them together” (“concatenate” them). Then use them as a PIC WORD variable in your program.
    You are able to read the individual button presses, but are having trouble putting them together to make the variable.
    Is that close?
    -Adam-
    Quote Originally Posted by Pic_User View Post
    Hi savnik,
    Is that close?
    -Adam-
    Ok, well that makes a bit more sense to me...
    getword:
    for x = 0 to 3
    keyin(x) = key 'save the individual keypresses
    next
    outval = ( keyin(0) * 1000 ) + ( keyin(1) * 100 ) + ( keyin(2) * 10 ) + keyin(3)
    Jun 2006
    Hi savnik,
    Is that close?
    -Adam-
    yes , i want it
    Perhaps somthing like this will do what you want.
    getword:
        value = 0
        for x = 0 to 3
            SELECT CASE x
               CASE 0
                  value = value + (key * 1000)
               CASE 1
                  value = value + (key * 100)
               CASE 2
                  value = value + (key * 10)
               CASE 3
                  value = value + key
            END SELECT
        next
    Jun 2006
    Quote Originally Posted by Ingvar View Post
    getword:
        value = 0
        for x = 0 to 3
            SELECT CASE x
               CASE 0
               CASE 1
               CASE 2
               CASE 3
                  value = value + key
            END SELECT
        next
    Thank you
    I wanted something like this
    Jun 2006
    sorry but my english is not good
    when press the button 2 on keyboard the LCD show 2 on first position and after when press the button 4 on keyboard the LCD show 4 on second position etc.
    I want the number 2,4,3,8 to be a variable (dec 2.348)
    You want the variable in memory (whether it be a byte or a word) to be:
    x = 2.348 ?
  1. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  2. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  4. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  5. calculation problem
    Last Post: - 31st March 2006, 16:23
