inputs on 12F675 (or for that matter any PIC)
Results 1 to 3 of 3
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default inputs on 12F675 (or for that matter any PIC)
    Hi all,
    Short of using interrupts on GPIO change, is there any way to have the digital inputs latch up until read. I think I sorta want an interrupt type of thing but without all the interrupt programming. I remember the old 6821 PIA had provision to latch the inputs, if they changed and cleared when the input register was read. Any such sorta thing available on PICs?
    I am, BTW, R'ingTFM but aren't up to that bit yet.
    I will be having a pretty short change on the inputs with the possibility of missing them while off doing other things. Perfect scenario for interrupts I know, but I just wanna do it the lazy way.
    Serve me bloody right if I hafta use interrupts, won't it?
    I have done the design with RS flip flops, which works beaut, but takes up too much real estate on the PCB.
    Peter Moritz.
    New South Wales,
    Australia.
    How many inputs do you need to 'latch' ? And do you need to catch the 'change' or just that there is or has been a high level on the input since last read?
    The only way I can think of without using interrupts or external hardware is to set up TMR0 and TMR1 (for 12F675) as counters. The value of the TMR registers will then be different between reads if the pin(s) have changed from low to high.
    /Henrik Olsson.
    I did something like this a long time ago to catch a change:
    X VAR BIT
    START:
    LET X = (YOUR INPUT PIN)
    NAP 4
    IF X <> (YOUR INPUT PIN) THEN RUN
    GOTO START
    RUN:
    DO YOUR THING HERE
  1. Midi, Interrupts and Pic better than SX28?
    By Lajko in forum mel PIC BASIC Pro
    Last Post: - 27th September 2008, 00:26
  2. Using portb as inputs PIC goes crazy
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2005, 14:15
  3. Long Distance Input's to Pic
    By GregK in forum General
    Last Post: - 21st April 2005, 09:37
  4. Serial Pic to Pic using HSER
  5. Pic 12F675
    By sherm in forum mel PIC BASIC Pro
    Last Post: - 12th March 2003, 12:04
