Average Values and digital filter ...
Results 1 to 12 of 12
    Dec 2006
    http://rentron.com/PicBasic/LM34.htm
    FOR sample = 1 TO 20 ' Take 20 samples
    ADCIN 0, temp ' Read channel 0 into temp variable
    samples = samples + temp ' Accumulate 20 samples
    PAUSE 250 ' Wait approximately 1/4 seconds per loop
    NEXT sample
    temp = samples/20
    This might work for you.
    Averaging 16 bit values without using 32 bit math?
    http://www.pbpgroup.com/modules/wfse...hp?articleid=7
    Smile
    Hi, Jorge
    Why not place your sensor in a dummy product ??? ( With same thermal mass - and even approaching shape, if convective heat transfer ).
    Result would be much more precise ... and doesn't keep you from an averaging !!!
    Darrels' averaging routine is pretty slick. I would go with that if at all possible.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    For Temperature A2D (0-1023), a favorite of mine if T changes are gradual and code space is a premium...
    pseudo-recursive filter (similar to Darrel's except without the smarts)
    A2D var word
    AVE var word
    ' Get new A2D value
    A2D = new A2D Value
    ' Smooth data
    Ave = ((((AVE<<1)+AVE)<<1)+AVE+A2D)>>3  'AVE = (7*AVE + A2D) /8
    ' More stuff here if you want
    Goto Main
    depending on the smoothing required, you can adjust and change the 7 & 8 in the AVE equation to 15 & 16, 3 & 4, etc., depending on what you need in the way of filtering
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Nov 2004
    Default thanks to all...
    ...as always you have helped me in finding the path, thanks for your precious time and for your hints !
    Darrel´s solution (really good) and the this last one (Paul´s) are on the spot...
    Thanks again !
    regards, Jorge
    Hey jorge,
    Hope it works out for you.
    The only thing it's missing is hysterisis. No matter how much you average, there's always a point where the reading bounces back and forth between two digits.
    To illiminate that "wobble", I added some hysterisis to the averaging routine and posted them a couple times ...
    http://www.picbasic.co.uk/forum/showthread.php?p=13267
    Never did get a response, but I've used them myself since then so at least now I can say that they do work.
    HTH,
    Feb 2005
    Smile
    Just wanted to say thanks to Darrel, I used this averaging routine in one of my projects that was driving me crazy and it solved the problem I had.
    THANKS!!!
    Always nice to hear things are working.
    Thanks for letting me know peu.
    Feb 2008
    Michigan, USA
    Default Averaging lots of numbers
    Hi all,
    I have the need to slow things down a bit. I'm running a 18F1330 at 32 MHz executing a sense loop for ultrasonics each 32 mS. I have tried to use DT's averaging routine with a 250 reading average, but it still reacts way too fast. I need to dampen it to a 2 or 3 second response so that it doesn't drive the mechanical parts nuts.
    It doesn't look like I can just change the AvgCount to a larger variable without messing it up.
    Anybody ran into this before?
    Thanks for any input while I try and think through this.
    Bo
    Feb 2008
    Michigan, USA
    Default Progress
    After looking closely at my code, I realized that I had tried to tweak DT's code.... as always, likely a mistake....
    Went back to the original and it is working more like need. Further testing.
    Move along, Nothing to see here.
    Bo
  1. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  2. 16F877A problem: "coupled" digital values
    By Lupo83 in forum General
    Last Post: - 4th December 2007, 13:46
  3. 2nd Order Digital Filter for 24-bit
    By sefayil in forum mel PIC BASIC
    Last Post: - 2nd December 2005, 22:55
  4. digital filter
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 15th September 2004, 02:28
  5. implementig digital filter and my problems????????
    Last Post: - 2nd June 2004, 19:06
