Driving a 180ma relay from PIC port
Results 1 to 22 of 22
    Default Driving a 180ma relay from PIC port
    Does anyone know of a transistor I can use that has enough gain to sink the ground connection on a relay that's drawing about 180ma? (Open collector configuration). Using a 16C65B...can't remember how much current a PIC can source.
    Tried a 4401 and some others but they won't latch on.
    THANKS
    Dec 2006
    2n3904 200 mA
    or you can go wild with a 2n2222 1.0 A
    Yeah but the PIC won't supply enough current to keep them latched on. I tried a 4401...same animal as a 2222.
    Will you provide a part of scheme ... ???
    Apr 2006
    New Hampshire USA
    Smile latching on
    Quote Originally Posted by Michael View Post
    Hi Michael,
    The PICs supply 25 mA per pin. That should be more than enough to hold those small signal transistor on. You may be looking at a different type of problem.
    -Adam-
    Quote Originally Posted by Pic_User View Post
    Hi Michael,
    -Adam-
    Do you have a ~1K-ish resistor on the base?
    Dec 2006
    Talking
    use this circuit found towards the bottom of the page
    http://rentron.com/PICX6.htm
    I'm driving a 2N4401 with a 1K....even did a 560 ohm. An open collector config to turn on/off the ground circuit to the relay.
    I'm actually using the input to the LM317 on my power supply (around 8 volts) for positive relay voltage. (5v relay)
    Using pin D4 on the PIC, which works fine (goes high for 15 seconds) but using the transistor to the relay will just give a momentary pulse and won't engage.
    However, if I tie the ground circuit directly and bypass the 4401, the relay works perfectly....so I know the power supply is fine.
    Maybe the transistor on resistance is too high but like I say, surely there's a part someone has used to sink 180ma without a problem.
    Question Hadware details ...
    Hi, Michael
    Could ever your Pic have a RESET when power applied to your relay ... mmmmh ???
    That could be a very good explanation ...
    do try a LED instead of the coil ... just to see what's happening ...
    sooo ...
    1) do you have a BIG tank capacitor on your pic supply ( say 1000µF + )???
    2) do you have the .1µF capacitor between vdd and vss ( the closest to the Pic )
    3) did you think to the reverse diode ( 1n400x) // on the relay coil ???
    PS ... once more: a scheme IS necessary to the troubleshooting !!!
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. destroying my last pic? driving a miniature motor
    By Michael Wakileh in forum Schematics
    Last Post: - 28th August 2007, 09:38
  4. serial port control relay
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2006, 23:56
  5. Pic to Pic communication?
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 11th April 2004, 19:41
