Originally Posted by
dragons_fire
when i first started building this, my intention was to put the battery between the 2 motors inside the red fibreglass. because i wanted lots of capacity, and a higher voltage, i added them to the top. so now i have lots of room insid the chassis.
i will probably make tubes to go around the motors, and hopefully that will help.
I might also cast a lead "brick" to fill in the space between them to make it a little more stable on angles, and for more grip. the only problem is that i will lose some endurance because the motors will need to haul more wieght.
ive been working for the last ten days, but i get the next 4 off, and its raining like crazy here, so i should get some time this weekend to play with it a bit more.
After i get the "interference" problem figured out, i will have a video up here of it driving around. i have written the code for it to speed up, drive, sense obsactles, slow down and then turn and drive that way..
