TreadBot
Results 1 to 40 of 177
Thread: TreadBot
    Apr 2006
    Alberta Canada
    ok... so im not sure whats going on now... i think im getting some kind of interference off the motors.. if i move the board about 3" away from the chassis, everyhting works beautifully. then if i put it back near the motors, it cuts off. i havent added caps across the motor leads and case yet, but i may try that tonight..
    im not sure, but when the voltage gets low enough, the PIC should reset right? and it appears from my LCD, that everything is just locking up..
    it does kinda move though.. i will keep working on it, and let ya all know when i find something...
    mmm, what happen if you try to use the internal OSC (if there's)
    Is there a lot of unconnected I/O?
    I don't remind your configuration fuses, but you could try to disable the Brow-Out detect or play with it's threshold voltage.
    Apr 2006
    Alberta Canada
    i have played with the fuses, and the threshold... didnt seem to help... im not sure whats causing it to cut out when the motors are close to the chip..
    i will try the int osc, and see if that helps...
    Quote Originally Posted by dragons_fire View Post
    For S & G 's, maybe throw a couple of thicknesses of aluminum foil between the board and the motors (taped up or coated somehow of course so it doesn't short out) and ground the foil...see what happens... Might help with the EMI if there is any.
    And if it doesn't work...at least it'll keep little green aliens from invading your Treadbot with their evil mind control devices!
    The aluminum foil will work for aliens but if the problem is a magnetic one you will need something with a high magnetic permeability. Hold a compass near the motors when they are running and see what happens. Use one that you will not care if it gets reverse polarized.
    If this is the problem, all you should need is a thin piece of cheap steel (roof flashing) that is a little larger than the board being that the motors are underneath it.
    Apr 2006
    Alberta Canada
    Ive been playing with it a little bit, and if i move the board up about 3", everything works great... thats what makes me think its an interference problem instead of a "low voltage" thing... i would prefer to keep eveything as close as possible, so its not top heavy..
    my sidekick still isnt working, so i have been spending most of my time on it, but when i get it going again, this robot should be driving around my house all the time...
    To me that sounds more and more like a magnetic problem. A magnetic field will drop off something like an inverse square, RF does not. (some one will want to correct this) At least if it was RF, it would most likely carry more than 3"
    A little info http://www.lessemf.com/guidelines.pdf
