Like Mr_E said about the power traces.
NICE JOB!
Just concentrating on the Power&Ground right now.
<img src=http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1578&stc=1&d=117761534 8>
mmm nice catch!
I think the PING's backwards too.
<img src=http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1579&stc=1&d=117761982 8>
i have never had this many problems with my boards... i have fixed everything that was mentioned... i took out that cap, increased the sizes of power and ground traces (and made them go all around the board), and i flipped the "ping" around too..
i dont know how i got that one backwards, it was fine all the other times i designed this...
thanks guys....
another update... im still working on trying to fix the computer in my car. its made by mitsubishi, adn apparently the caps go bad, and need to be changed.
i made a new board, and it all seems good. i think the old PIC is still good too (im not sure though). i tried to flash an LED on RF0, but its not working.
i can program fine, and then i can read the code from the PIC and its all the same. i think im just forgetting something somewhere.. and remember, im still somewhat new to this...
DEFINE OSC 20
define xt_OSC
CMCON = 7
ADCON1 = 7
start:
high portf.0
Pause 1000
low portf.0
GoTo start
yeah i already repaired tons of those beauties awhile back, and yes they had Caps failure... but some has Microcontroller failure as well. Maybe you could have a look at the following which explain it to you better than i could
http://www.ecmtogo.com/ECMTips2.htm
And yes, they also have plenty faulty contact/wiring problem too... good old time
Your config fuse setting is wrong, i suggest you open the .INC file in the PBP folder to see how they set the default one AND to have a look at the following
Make sure you really disable ALL analog stuff with your current settings AND that you disable the LVP mode in your config fuses.
