Never done THAT before.... Yes I have.
(that's how I knew to look for it)
it is actually my first time doing that... but im sure it wont be the last..
at least i enjoy making the boards, i think its part of the fun. i also only soldered on the basics, so its not much of a loss of money...
i cant believe i didnt notice it.. i started from scratch on the second board, and i still didnt get it right...
thanks again!!
it may not be too hard to cut some traces and run a couple jumpers.. i like having everything nice and clean.. and like i said, i enjoy making the boards... later on, i will try to post a pic of my 16f88 controlled lightning trigger for my camera. seems to work using a camera flash, hopefully it will work with lightning....
i used a photocell (resistor) connected to an ADC pic on the PIC, and it takes 2 samples, and compares them. if the second one has a greater value, then it triggers the camera. if i use a flash (disposable camera parts) it will take a picture and capture the flash, so it should be fast enough for lightning...
well, i have only breadborded it, so i can always change it to a transistor.. http://www.solorb.com/elect/lightning/
i dont think that a flash is slower than lightning. i may miss the initial bolt, but i have gotten a few stikes by just pressing the shutter button when i see the flash...
