youre right, the vreg im using has an output on the tab. so thats been fixed now, but i still dont think that was part of my probelm, since everything works when the pic isnt in it..
i tired taking out all the MCLR stuff so it doesnt connect to anything, and it still heats up pretty quickly.. im starting to wonder if the chip is destroyed and that causing it to heat up now, or if there is still something wrong..
in the schematic, MCLR is connected through the diode to the resistor and cap. its also connected to the prog pin. i see where you thought it connected to Vdd, but it actually doesnt.. the data sheet i have, its a notes page on page 34. page 35 has stuff about resets and shows the same wiring that i have.
when i etched this board, there is copper on the top too, and some of my pins dont match up perfectly, so there could be a short under the socket. i checked before i soldered, but i could have missed something..
im going to play around with the toner transfer, and see if i can get it any better. if not, i will probably make a new photoetched board.
so changes to the board now are:
vreg tab connected to output,
no more ground planes
MCLR stuff layed out better,
copper pads on top are gone, (except for the top traces)
.01 gap between pads and traces, .02 betweeen traces
more gap between Vdd and standoffs (Vss)
thanks for the comments on the old boards i made.. when i started, i thought the sharpie was the only way to do it, and that it needed sprecial equipment to make boards any other way. the photoetched one, was actually something called RCAP, its an autopilot for RC planes. its an opensource project, and the board layout was straight out of their website. it runs at 2400 baud, so i dont think it will have too many problems with 90 degree corners.
but i will stop typing now and go play with my toner and see what i can do..
