TreadBot
Results 1 to 40 of 177
Thread: TreadBot
    this method may have it's advantage for sure. My biggest concern, and also why it doesn't turn me on, is the precision of your layout alignment when doing a double sided PCB. With transparencies film it's just soooo simple to do.
    You place your 2 films on a white sheet (or lightened table if you have any) align them perfectly, stick them together with tape on 3 edge (create a kind of pouch) and VOILA!
    Place your film on your exposure gizmo, place your PCB the way you want without having to care about alignment, start neons, few minutes later it's done... on both side!
    But yeah... you have to deal with exposure time, chemicals etc... but it's working really well. I did many successful prototype PCB using fine pitch SMD components, i can't confirm if the toner method would work as this well. But as long as it's working for you... life is good
    If you scratch your film, or you use a fine tip ink pencil.. or simply print it again. Make sure you inspect them carefully first.
    If you mess the toner transfer, what happen? is this easy to remove? What is the aprox cost of a toner-transfer sheet?
    Films can be reuse again and again.
    I didn't realize you were using the pre-sensitized boards. I tried that too... used a couple of 15w flourescent bulbs for exposure (not even close to the right equipment to be sure), couldn't really get the hang of it. I suppose it was because of those bulbs I used.
    Toner Transfer Sheets $ - they weren't cheap, cheaper than presensitized boards, but a guy still has to buy the blank copper. If you screw up the toner, sure you can take it off with a steel wool pad, but then you have to start over again, transfer it somehow, blah blah blah.
    I'd really love to get my hands on one of those Protomat S62's for the house...only $25K with the options...pocket change! NOT!
    Yeah it's one of those machine some may want to have hanging on their bench
    Maybe your tube haven't the right specs, were to far of your PCB, or your exposure time was not appropriate. You have to use special wave lenght tube (UV). regular Black-light tube (or lamp)have nothing to do with that. I usually pre-heat my tube before for 1-2 minutes.... once again for safety sake.
    Once you have did few experiments, you know how much time your exposure time will be... it's almost the same everytime.
    At least you will scrap 1 big PCB. if you're using 2-3 tube, this MUST take less than 2.5 minutes.
    1. Start the exposure lamps and hide major part of your whole PCB with an opaque material
    2. wait at least 1.5 minutes
    3. move the opaque material to reduce the 'hidden from UV' PCB area every 5-10 seconds
    4. develop the whole PCB and look where your PCB look the best.
    At the bottom of this link, it's almost what i said... but in english
    http://www.turbokeu.com/myprojects/pcb.htm
    Enjoy and have fun with the pcb etching and... drilling job
    EDIT: i heard some use now ultraviolet LEDs...
    Apr 2006
    Alberta Canada
    the board is done now, and some of the stuff is mounted to it. im using the pic18lf6585, which is the low voltage one (but should work from 2 - 5.5V) and i have a 5V 5A regulator. when i connect the battery without the chip in its socket, everything works fine, as soon as i stick the chip in, the PIC and the Regulator heat up... i havent let the smoke out "yet" but they did heat up lots, and might not be any good anymore... i checked to see if i had Vss or Vdd backwards (so when i put the chip in, it would short out) but everything looks good.
    if anyone has any ideas of why its doing that, please let me know.. heres a pic of the bottom of the board on my first attempt with the toner transfer method. the top didnt turn out as good, but there is only 3 traces on the top, and they werent affected.
    my last question for everyone is: For PICs that have multiple Vss and Vdd's, do they all need to be connected (they are on this board), or are they connected internally?
    All VSS and VDD have to be connected.
    From what i see on your picture, there's few potential traces short-circuit. Assuming there's no routing mistake and the original design worked, You should do a visual inspection first then use you Multimeter.
    <img SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1538&stc=1&d=117673623 8">
    Seems to be caused by a lack of etching time or toner transfer... i can't tell.
    The overall layout and routing looks good, the final results... so so. I try to avoid 90 degree routing, the etching process work better. It have also other benefits in high frequency.
    I also try to avoid unconnected 'ground plane dedicated' copper islands.
    Check if there's any polarised capacitor connected backward.
    All Vss's must be connected together outside of the chip, same with Vdd.
    And nice job on the PCB...really. The only things I was going to mention...mister_e already covered them...
    As far as overheating, with the PIC out of the socket and power disconnected, if you put a meter between any Vss and Vdd, what do you get for a resistance reading? How about a Vf reading (normally seen as a continuity test on a meter when really it measures a diode's forward voltage)... Now try it with the PIC in the socket and power still disconnected?
    Then hook up the meter to Vdd & Vss, turn it on volts, put the PIC in the socket, and plug in power just long enough to read the meter. Did the meter come up to system voltage? In other words...dead short somewhere on the board?
    Apr 2006
    Alberta Canada
    1.036kohm across vdd and vss "with" and "without" the chip. i tried another regulator that isnt mounted to anything, and it comes back with the same reading.
    5V without chip, 4.48V with chip
    when i put my meter on the doide symbol (i have never used it before and dont know what it is), i get .324V without any power applied to the board (im assuming there isnt supposed to be)
    Quote Originally Posted by dragons_fire View Post
    1-ish Kohm... hmmmm...no dead shorts. Something is turned on by the PIC.
    Something's loading it down! Try disconnecting the motors? Try disconnecting and unsoldering stuff until you find the 'leak'. Maybe change your program a bit to make absolutely sure nothing is being driven for X seconds before something starts to happen.?.?
    Try this with the 'diode' symbol on the meter. Hook the meter up to a plain ol' diode, 1N4148, whatever you've got handy. Whatever the meter reads (within range of course) is what the forward voltage drop of the diode is and if the meter leads are connected correctly. The datasheets on the diode will tell you what the nominal values are. You can also use this function to correctly identify leads on a transistor.
