A/D conversion problem on 18F4431
Results 1 to 4 of 4
    Mar 2007
    Default A/D conversion problem on 18F4431
    Ver 2.46, MPMASM 5.1
    I have the processor above with an analog accelerometer. The values I'm getting from the conversion are incorrect with respect to the reference voltage supplied. I have tried numerous configuration changes but no luck.
    Setup:
    Ref+ voltage is 2.6v on Pin RA3,
    Ref- is Gnd.
    measured voltages
    RA0 = x-dir 1.1v
    RA1 = y-dir .9v
    RA2 = z-dir 1.8v
    Acc. value 1g=800mV/g.
    I was expecting to see the voltages for x and y to be ~1.3 volts or a value displayed of ~ 512 when the acc. is in the horizontal position. What I get now are reading of 900-1000. I tested this on an 16F877A and it preformed as expected. Also, I tried all 1.5, 2, 4, 6 g settings. No change.
    Code is below:
    DEFINE OSC 8
    OSCCON = %01110010
    ' Define LCD pins
    DEFINE LCD_DREG PORTD 'LCD data port
    DEFINE LCD_DBIT 4 'LCD data starting bit 0 or 4
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_RSREG PORTC 'LCD register select port
    DEFINE LCD_RSBIT 1 'LCD register select bit
    DEFINE LCD_RWREG PORTC 'LCD read/write port
    DEFINE LCD_RWBIT 2 'LCD read/write bit
    DEFINE LCD_EREG PORTC 'LCD enable port
    DEFINE LCD_EBIT 3 'LCD enable bit
    wAdval var word
    bLoop var byte
    wMaxvalArray var word[3]
    wMinvalArray var word[3]
    m var byte
    'I/O port defs 0=out, 1=in
    ' atod
    TRISA = %00001111 ' AI 0=x-dir, AI 1=y-dir, 2=nc, AI 3=z-dir
    ' DO 4=g1, DO 5=g2, DO 6=nc, DO 7=nc
    PORTA = 0
    TRISB = %11111111 ' DI 0=sel, DI 1=up, DI 2=dn, DI 3=end
    ' DI 4=nc, DI 5=LVPGM, DI 6=PGC, DI 7=PGD
    PORTB = 0 ' PORTB lines low to read buttons
    TRISC = %00000000 ' All DO's 3 LCD, 4=cont, 5=LCD_RW, 6=LCD_RS, 7=LCD_E
    PORTC = 0 ' PORTC lines low to read buttons
    TRISD = %00000000 ' not used
    PORTD = 0
    TRISE = %00001000 ' DI 0=sleep, DO 1=nc, DO 2=nc, DI 3=MCLR
    PORTE = 0
    ' port assignments
    aACC_g1 var PortA.5
    aACC_g2 var PortE.0
    aACC_SLEEP var PortA.4
    ANSEL0 = %00000111 ' set 0,1,2 to AI, rest to Digital
    ANSEL1 = %00000000 ' set 0 to Digital, rest are n.c.
    INTCON = %00000000
    INTCON2 = %00000000
    INTCON3 = %00000000
    ADCON0 = %00000000 ' sin. shot meas, multichan, sim M1, DONE, a/d mod OFF
    ADCON1 = %01011000 ' Vdd-ACC volt, Vss refs, FIFO en, buffer stuff
    ADCON2 = %10000011 ' rt just., No conv delay, FRC/4
    ADCON3 = %11000000 ' int. unimpl, all trigs. disabled
    ADCHS = %01000000 ' group sel., Group D=AN3, Group B=AN1, Group A=AN0
    ' wake acc.
    aACC_SLEEP = 1
    ' 1.5 g
    aACC_g1 = 0'01
    aACC_g2 = 0'01
    ADCON0.0 = 1 'a/d mod ON
    m = 0
    wMinvalArray[m+1] = 1024
    wMaxvalArray[m+1] = 0
    wMinvalArray[m+2] = 1024
    wMaxvalArray[m+2] = 0
    wMinvalArray[m+3] = 1024
    wMaxvalArray[m+3] = 0
    ' mainloop - the mother of all
    mainloop:
    for m = 1 to 3
    if m = 1 then ADCON0 = %00000001
    if m = 2 then ADCON0 = %00000101
    if m = 3 then ADCON0 = %00001001
    ADCON0.1 = 1 ' Start Conversion
    Pause 5
    notdone:
    If ADCON0.1 = 1 Then goto notdone
    Pause 5
    ' good conversion, grab the data
    wAdval.LowByte = ADRESL
    wAdval.HighByte = ADRESH
    if wAdval < wMinvalArray[m] then wMinvalArray[m] = wAdval
    if wAdval > wMaxvalArray[m] then wMaxvalArray[m] = wAdval
    next m
    lcdout $fe, $1, "x", Dec4 wMinvalArray[1], "-", DEC4 wMaxvalArray[1], _
    "y", Dec4 wMinvalArray[2]
    lcdout $fe, $c0, "-", DEC4 wMaxvalArray[2], _
    " z", Dec4 wMinvalArray[3], "-", DEC4 wMaxvalArray[3]
    Goto mainloop ' Do it forever
    Do the returned values on the LCD change as you would expect them to as you move the accelerometer?
    With respect to each of the values returned, if you applied a constant offset, would that fix your numbers and make them read what you would expect them to read?
    Mar 2007
    Default Offset
    skimask,
    not sure yet, I want to take the voltage measurments and see how they look with respect to orientation.
    Basic question, if I give the micro a ref voltage, should it not scale the number from 0-1024?
    Another item I need to investigate are the Tad and conversion clock bits, I guessed at what values to put here.
    thanks
    t
    Quote Originally Posted by ttease View Post
    skimask,
    thanks
    t
    If Vref+ is what the accelerometer puts out at max, and Vref- is what the accelerometer puts out at minimum, then, yes, it'll scale from 0 to 1023.
    If not, either you'll want to do some sort of scaling to the end result. Problem is, if you're input range is less than your output target range, you'll end up losing precision (I just did a post for another guy talking about that elsewhere).
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. A/D conversion problem with 18F2455
    By abdy37 in forum mel PIC BASIC Pro
    Last Post: - 7th May 2007, 15:53
  4. A/D conversion problem with pic16F88
    By Tapio Linkosalo in forum mel PIC BASIC Pro
    Last Post: - 18th August 2006, 12:42
  5. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 19:57
