Lcd Backlight
Results 1 to 3 of 3
Thread: Lcd Backlight
    Lightbulb Lcd Backlight
    Was Reading A Spec Sheet On The Backlight Of These Displays
    Say 1500 Hrs Could That Be Right Is So Whats A Better Way This Is Not Nearly Enough
    Any Info
    Quote Originally Posted by jcleaver View Post
    Any Info
    LED backlight or EL backlight?
    LED backlight @ 1500 hours? Only if you're pushing it at the max current and it's really hot in the area.
    EL backlight @ 1500 hours? Very possible, but again, probably at the max current rating.
    How to make it last longer? Don't drive the backlights at their maximum current levels.
    Any Info
    Only have the light on when you actually need it on. Saves power too.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Backlight Proper Wiring
    By DavyJones in forum General
    Last Post: - 27th July 2009, 00:01
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. Easy LCD BackLight
    By Melanie in forum Schematics
    Last Post: - 17th October 2004, 14:18
