PortA.2 on a 16F676
Results 1 to 4 of 4
    Default PortA.2 on a 16F676
    I have a circuit designed around a 16F676. Basically, I am feeding the mains sine wave (after the transformer, thru' a 22K resistor) to PortA.2. I did a pulsin to measure the width of the positive cycle, and got a reading of around 120 (12 ms).
    Since I am feeding a sine wave, I dont expect to get a precise reading, as I realise the clipping would happen somewhere on the rising and falling edges. This would be allright. (Actually for 50 Hz, I would have expected the reading to be *less* than 100, or 10ms for a half cycle, but like I said I dont need absolute values)
    But, the problem is this; the same signal fed to any other PortA pin gives a much higher value (175 or thereabouts).
    I could of course shift the input to the other pin(s), but my PCB is designed.
    What could be causing this? What is different about PortA.2 from say A.0,A.1 or A.5?
    BTW, I have configured the PIC for all digital, comparators disabled and weak pullups disabled.
    Any help would be appreciated!
    Anand
    Red face
    A look at the datasheet shows A.2 is a schmitt trigger input ... not so good for such measurements.
    Measurement differences with other ports come from here ...
    The only way to keep your board as-is would be to raise the voltage from your trafo ... the trigger levels occur on the "very low" ( read closest to zero crossing) part of the sine.
    no real hope of saving your board ...
    oh, missed that.
    Thank you so much; fortunately I do have a spare pin I could use.
    I still dont understand why the pulsin should not be 10ms (50 Hz, positive half cycle) or *less*, rather than the roughly 17 ms that I'm getting?
    Anand
    Just look at your sine w/the scope ...
    some surprises guaranteed !!!
  1. 16f684 Porta.2 Instability
    By JDM160 in forum mel PIC BASIC Pro
    Last Post: - 5th November 2006, 02:38
  2. SEROUT workaround for 16F676
    By rkeene0517 in forum Code Examples
    Last Post: - 12th February 2006, 03:39
  3. Using 16f676 with comms
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2005, 20:01
  4. Problem during compilation 16F676
    By mat janssen in forum mel PIC BASIC Pro
    Last Post: - 7th October 2005, 07:05
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 03:46
