OPTION_REG = $7f syntax error
Results 1 to 7 of 7
    Quote Originally Posted by ttease View Post
    ver 2.46, MPASM 5.1
    I think it is an problem with the 18F4431. I can compile code for the 16F877a with both MPASM and the default compiler and it works just fine. I have tried to compile a simple program with OPTION_REG = 1 and it gives me a syntax error.
    thanks
    t
    Download the datasheet for the 18F4431 and do a search for the phrase 'OPTION_REG', then do a search for the word OPTION.
    Get back to me on what you find...
    Last edited by skimask; - 10th April 2007 at 19:45. Reason: Did some searching at the Microchip website...go figure...
    OK, that explains it.... The 18F4431 doesn't have an OPTION_REG. What is it you are trying to do by setting it? You said that the it did work a day or so ago but never that you changed target device....
    /Henrik Olsson.
    Mar 2007
    Default What I figured was...
    Thanks and I finally get it. It did work on the 16f877a but I have to remember, each PIC device has its own little kingdom of parameter and register. I mistakenly figured this was a common, like TRIS and PORT, parameter among all PIC devices (PortB pull-ups sounds common).
    I started with the 16f877a and that has become my 'normalized register' set.
    I'll try to pay more attention to the datasheets in the future.
    thanks
    t
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  3. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  4. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  5. Working with indivividual bytes of an array
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2007, 20:16
