Help with HPWM on 18f6520
Results 1 to 18 of 18
    Apr 2007
    Default Help with HPWM on 18f6520
    Hello,
    My first post here so don't be too hard on me!!
    I am currently playing with the HPWM command on the 18F6520. It works ok on CCP1 and CCP2 but I cannot get it to work on CCP 3,4 or 5.
    I have tried a few different setup configurations, however, at present I am stuck!
    Any help or ideas would be greatly apprciated.
    Andy
    Quote Originally Posted by Andy Wood View Post
    Hello,
    Andy
    Can't see no code, can't give no help.
    Apr 2007
    Thanks for the reply Skimask.
    Here is a copy of the code:
    HPWM 1,127,245
    HPWM 2,127,245
    HPWM 3,127,245
    HPWM 4,127,245
    HPWM 5,127,245
    GOTO main
    When using a 5v supply, this produces 2.5v on CCP channels 1 and 2, and 0v on CCP channels 3,4 and 5 (which are on port G).
    I also tried adding TRISG = 0 at the start, to force CCP 3,4 & 5 to outputs but nothing changed.
    Andy
    HPWM 1,127,245:HPWM 2,127,245:HPWM 3,127,245:HPWM 4,127,245:HPWM 5,127,245:GOTO main
    Andy
    That's it? No defines, don't know how fast the oscillator is runng, no registers set up, no nothing?
    Read the manual, try again...
    HPWM only works with CCP1 & CCP2. Beyond that, you'll need to manually configure hardware PWM.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Apr 2007
    Hello Bruce,
    Thanks for the reply. I have read the manual and cannot find where it says HPWM is only for CCP1 and CCP2. Maybe this is an undocumented "feature"?
    Anyway, I do appreciate your response - I have been pulling my hair out! Thank you for your input.
    Andy
  1. need help on hpwm
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 16:49
  2. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 16:05
  3. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  5. HPWM usage with the 18F6520
    By slxrti in forum mel PIC BASIC Pro
    Last Post: - 17th November 2005, 17:57
