Pic12f683, Trisio, High Z, A2d
Results 1 to 10 of 10
    Vb = 4v
    Va = 9v
    Ic = 280 mA (while in LOW state)
    Ic = 0.05 mA (while in High Z state)
    if this helps at all
    Feb 2003
    You need to use an NPN transistor to drive R3 not the PIC.
    Because the PIC is powered from 4V the voltage on its pins cannot exceed 4.6v due to internal protection diodes. This means that even when in its hi-z state current will still be flowing via R3 which would explain why you stil have current flowing even when it is supposed to be off.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    T.Jackson's Avatar
    T.Jackson Guest
    Smile
    Keith is 100% correct. The base of Q2 would need to be at the same level as Va in order for it to switch off. 0.6v or more below Va would mean that it's biased on.
    You will find that in its current form Q2 is actually always on.
    Trent Jackson
    I'll try that solution as soon as i can and get back to you to see if it worked out. but everything seems logical thanks.
    jose
    The NPN Transistor driving R3 works fine. thank you all for your help it is greatly appreciated!
    jose
    Jul 2007
    if you put a resistor on the battery for a short period you can decrease surface charge a lot and get an even more accurate reading (closer to actual charge held) on the battery
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. confused problem with interrupt in a working program
    By illuminator4 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 18:01
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  5. Serin and TMR0
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 17th May 2006, 15:58
