newbie help : subsumption
Results 1 to 5 of 5
    Apr 2007
    Default newbie help : subsumption
    i'm new to pic basic and i'm trying to setup a simple subsumption architecture...
    can anyone help with this code :
    start:
    go_command = command_none
    stop_command = empty
    if go_command <> command_none then motor_output = go_command
    if stop_command <> command_none then motor_output = stop_command
    select case motor_output
    case stop_command
    portb = %00001100
    case go_command
    portb = %00000011
    end select
    goto start
    basicly i'm just trying to select the correct state based on when go/stop_command(s) are not command_none.
    I can't seem to select the second case, go_command, it always just assigns 00001100 to port b
    can anyone help
    thanks
    If you're using MELABS PicBasicPro then you can't have the IF statement like:
    You'll have to do:
    Endif
    HTH
    /Henrik Olsson.
    Apr 2007
    thanks for the help i've now got it working
    i have one last issue..
    the code as it stands :
    'manually select
    Seek_output = backward '1
    Evade_output = idle '2
    Panic_output = idle '3
    settle_output = idle '4
    start:
    'subsumption
    'if x is not in idle mode assign the output from that layer
    'if the layer is idle then move to the next..
    if Seek_output <> idle then
    motor_actuator = Seek_output 'state 1
    elseif Evade_output <> idle then
    motor_actuator = Evade_output 'state 2
    elseif Panic_output <> idle then
    motor_actuator = Panic_output 'state 3
    elseif settle_output <> idle then
    motor_actuator = settle_output 'state 4
    end if
    ' motor case statement only selects with numbers
    ' need to use text for clarity
    gosub motor_control
    goto start
    motor_control:
    select case motor_actuator
    case left
    portb = %00000001
    case right
    portb = %00000010
    case forward
    portb = %00000011
    case backward
    portb = %00000100
    end select
    now the motor control case statement selects ok when i use numbers but i would much prefer to use text, can anyone help..
    I'm not sure I understand that correctly but let's say that this work
    motor_control:
      case 1
        portb = %00000001
      case 2
       portb = %00000010
    end select
    Then set up some constants matching those numbers, like:
    Left CON 1
    Right CON2
    Forward CON 4
    Reverse CON 8
      case Left
        portb = %00000001
      case Right
       portb = %00000010
    'and so on.....
    end select
    Sorry if I misunderstood.
    /Henrik Olsson.
    Apr 2007
    that works !
    thanks for you help
  1. Newbie making an ignition timer
    Last Post: - 5th August 2012, 17:45
  2. Newbie 74hc595 question
    By manjero in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 22:22
  3. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 09:56
  4. PIC Newbie
    By azmax100 in forum Schematics
    Last Post: - 23rd February 2007, 04:52
  5. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 09:01
