PIC18F4515 Serin2 Maximum Array size
Results 1 to 9 of 9
    Default PIC18F4515 Serin2 Maximum Array size
    Can anyone help, please. I'm using a PIC18F4515 and PBP. I'm trying to recieve serial data into a byte array of 805 bytes. Everything I can find states that this should be possible, but anytime I go over 256 bytes it does not work. In fact this is one of the reasons I switched up from a 16F877(a) part, due to it's 96 byte limitation. I no longer get the error on compile, but it still doesn't work.
    Am I missing a configuration bit, include, ???
    Thanks in advance for any input.
    Sam
    Quote Originally Posted by millersamsr View Post
    Sam
    Are we supposed to guess at what your source code looks like?
    Even if we are, my guess is that your index variable for your array is a byte variable instead of a word variable.
    While the 18F's can have very large arrays, the STR function of SERIN, HSERIN etc, can only receive 255 bytes.
    To get around this limitation you can just use multiple STR's in the xSERxxx command. For instance...
    HSERIN [STR MyArray\255, STR MyArray(255)\255, STR MyArray(510)\295]
    HTH,
    ..........Deleted.......
    For instance...
    HTH,
    Somehow it looks like that last MyArray(510) won't work according to your explanation
    Why not? Oops OK, but you get the idea.
    Fix it for me skimask
    Hey...
    You're the asst_admin, not me.
    Last Post: - 14th June 2016, 07:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  3. RS232 receive an array (packet)
    Last Post: - 12th February 2008, 05:02
  4. Trouble with Serin2 and variable size
    By Ryan7777 in forum Serial
    Last Post: - 5th October 2006, 16:40
  5. Maximum variable array ?
    By Keith55555 in forum mel PIC BASIC Pro
    Last Post: - 7th May 2004, 14:29
