12f675 sensing temperature...
Results 1 to 5 of 5
Threaded View
  1. #4
    Quote Originally Posted by rossfree View Post
    Thank you skimask,
    but... I kinda want that 8 bit resolution. With Vref set at 2.55 volts, and using an LM34 temperature sensor outputing .01 volts per degree F, I get a digital number that corresponds very nicely with temperature... such that .8 volts in gives me a digital 80 out... representing 80 degrees F.
    Dropping off the top two digits doesn't change the resolution... it just lops off the top end.
    Can you help me figure out why it doesn't accept my statement:
    DEFINE ADC_BITS 8
    Thank you,
    Ross
    I didn't say drop off the top 2 bits of the upper byte, I said drop the top 2 bits of the lower byte (which are actually the bottom 2 bits of the result overall).
    I don't think you can have it both ways, well you can, but it's a bit more difficult.
    And why is 10 bits a problem? PBP can handle 10 bits easily, even on a PIC12F.
    DEFINE ADC_BITS 8 - which version of PBP are you using?
  1. Replies: 10
    Last Post: - 17th February 2012, 07:19
  2. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 19:19
  3. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 18:21
  4. Help for decimal conversion
    Last Post: - 15th March 2007, 18:20
  5. Serout "onewire.bas"
    By puru in forum mel PIC BASIC Pro
    Last Post: - 6th July 2005, 00:14
