16F88 - CCPMX strange fuse setting for HWPM
Results 1 to 6 of 6
    More than likely, you have manualy set the TRIS registers so that RB0 is an OUTPUT.
    That's the only thing that the DEFINE's will affect.
    Normally, the HPWM command will set the pin to OUTPUT on it's own, but in that case it needs the proper defines.
    "PIC-freaks", you calling me a Freak?
    Dang I hate when people know what I really am.
    Oh shoot, here's a big problem I forgot about.
    If you don't set the DEFINE's, when you use the HPWM command, it will set RB3 to OUTPUT since it's the default.
    If you have something providing a signal as an INPUT to RB3, it can cause a short and really screw things up.
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  2. RA6 & RA7 I/O setting on the 16F88
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2008, 19:32
