Problem with enumeration and EasyHID
Results 1 to 23 of 23
    There are internal pull-ups. And EasyHID configures them for Full-Speed, so you shouldn't need external ones.
    Did you use all the configs from post #11?
    In particular _VREGEN_ON_2L.
    Your original configs had that turned OFF, just want to make sure it's turned ON now.
    Should I take out that define statement?
    It doesn't really matter, it's fine even if not using a bootloader. But if you were using a bootloader it may have caused problems with the config settings, so I thought I'd ask.
    Apr 2007
    I used the config code from post 11, but _BORV_2_2L and _FCMEN_OFF_1H dont seem to be define for the 2550, so I took them out.
    Is there another file i need to include to get these fuses to work correctly?
    You still have MPASM 5.02 so it's _FCMEM_OFF_1H
    That'll change after you upgrade MPASM.
    _BORV_2_2L is defined for the 2550. I can see it in the .LST file in your .ZIP in post #10
    Can't image why there would be a problem with it. But since it's in the same line as _VREGEN_ON_2L, it makes me wonder if there's something else wrong with that line which caused the error.
    Apr 2007
    I looked at the list file and it should be _BORV_21_2L. So, now I've set the fuses correctly, nothing happens now. Windows doesnt pop up with anything, not even usb device unrecognized. I have no idea what could be wrong
    Apr 2007
    I set the fuses finally. The brown out reset voltage fuse is _BORV_21_2L, found this looking through the lst file. Now nothing seems to work, not even simple LED flashes. I have no idea what is going on.
    Now that you get "nothing". It seems like FCMEM_OFF is doing it's job, and now it's not running on the internal oscillator.
    I think your problem might be the 33pf caps on the crystal. Or a bad/wrong crystal.
    The datasheet shows that it should be around 22pf for 20mhz.
    With FCMEM_ON, the chip will switch over to the internal oscillator if the primary isn't working. You'll see LED's blink, but it's not the right frequency for USB to work.
    ___________
    Q. Why do they put braille on the number pads of drive-through bank machines?
    Mar 2005
    Iowa, USA
    Default O.t.
    Q. Why do they put Braille on the number pads of drive-through bank machines?
    A. The manufacture of the number pads on bank machines, have Braille on the numbers. Whether it is a drive through or walk up. It would be expensive to change the number pads on drive through machines, or put the braille enhanced number pads on walk up. The buttons being mass produced, are put on all of the number pads, no matter where they are located.
    Source:http://www.confusionwithin.us/docofbs/?p=11
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Apr 2007
    Okay I finally got it to work!
    I had to set the fuse values in melabs serial programmer as well as the fuses in the config files. I didn't know the programmer would rewrite the config values from picbasic pro.
    Thanks for the help guys!
