Problem with enumeration and EasyHID
Results 1 to 23 of 23
    Cool
    Quote Originally Posted by jizyjuice View Post
    Hi, I'm using a pic18f2550 with picbasic pro and easyhid.
    I get the files generated from easyhid to compile correctly. The problem is that when I plug in the usb cable, the computer never enumerates the pic, no new hardware found box on windows.
    I connected the pins correctly, i think, just as the schematic suggests on the easyhid website. I'm just trying to code something where it will send the a/d values from an RA pin to the pc.
    Any suggestions or tips?
    Thanks in advance
    Those that read this are supposed to help you figure out your code problems because we can all guess exactly how you have written your code. Am I correct in this assumption?
    Post some code!!!
    Apr 2007
    Heres the code that Easy HID created. I set up an led to see where the code stops at. It seems to stop after
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, . I guess this is because I dont have any code right now to send data, but I was more concerned with the pc recognizing the pic.
    If usbinit is called, doesnt the pc enumerate the usb device? It never shows that a hid device is connected. Is there something I am missing to get the pc to recognize this device?!
    DEFINE OSC 48
    DEFINE LOADER_USED 1
    USBBufferSizeMax con 8 ' maximum buffer size
    USBBufferSizeTX con 8 ' input
    USBBufferSizeRX con 8 ' output
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    ' * main program loop - remember, you must keep the USB *
    ' * connection alive with a call to USBService every couple *
    ' * of milliseconds or so... *
    usbinit ' initialise USB...
    ProgramStart:
    gosub DoUSBOut
    goto ProgramStart
    ' * wait for USB interface to attach *
    DoUSBOut:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBService ' keep connection alive
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    That's not the "Whole" code that easyHID created.
    You've deleted some things that are very important.
    If you just want to see it enumerate, change the main loop to this...
    ProgramStart:
    goto ProgramStart
    But that will neither send or receive any data.
    This also assumes you've setup your Configs properly.
    Apr 2007
    Oh, I took out the code for receiving data from the pc to the pic. I just want to communicate to the pc side.
    All the configs are what easyhid has set up. I will try just polling serviceusb and see if that can get the pic to enumerate. Thanks
    What Darrel talked about was the PIC configuration Fuses... which EasyHID don't create for you.
    http://www.picbasic.co.uk/forum/showthread.php?t=5418
    Apr 2007
    I still cant get the pic to enumerate.
    Here is my code for the fuses:
    LIST
    LIST p = 18F2550, r = dec, w = -311, w = -230, f = inhx32
    INCLUDE "C:\PBasPro Projects\AirDrum\PICBasicPRO\P18F2550.INC" ; MPASM Header
    __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    __CONFIG _CONFIG1H, _FOSC_XTPLL_XT_1H & _IESO_OFF_1H
    __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_OFF_2L & _BORV_2_2L & _VREGEN_OFF_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H
    __CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_OFF_3H
    __CONFIG _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    NOLIST
    Here is the main code again:
    DEFINE OSC 48
    ' the USB buffer...
    i var byte
    ProgramStart:
    'gosub DoUSBIn
    'gosub DoUSBOut
    High PORTB.0
    for i = 1 to 10
    Pause 2
    USBservice
    next i
    LOW PORTB.0
    for i = 1 to 10
    Pause 2
    USBservice
    next i
    goto ProgramStart
    ' * receive data from the USB bus *
    DoUSBIn:
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
    DoUSBOut:
    The LED lights up correctly, but the pic still does not enumerate even with calling the USBSERVICE. I have 0.5microF on VSUB, 20 MHZ crystal with 33 pF connected to it. D+, D- set up correctly. Bus powered.
    I have no idea what the problem is!
