Can't get switch to work
Results 1 to 6 of 6
    Apr 2007
    Default Can't get switch to work
    I'm just starting out and trying to create a very simple clock as a first project. I'm using a PIC16F628A and a DS1307 Real Time Clock. For some reason I'm unable to get any input response from a switch. I checked the wiring with a volt meter and it shows the correct voltage change when the switch is pressed so I assume I have overlooked something in the code. At this point I am just trying to have my display read 12:30 if the LeftButton is pressed. Any help is appreciated. My code follows.
    Jeff
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_BAUD 19200
    define DEBUG_MODE 0 ' 1 = inverted, 0 = true
    ' DS1307 control pins
    SDA VAR PORTB.1 ' DS1307 SDA pin #5
    SCL VAR PORTB.2 ' DS1307 SCL pin #6
    TRISA = %11111111
    LeftButton var PORTA.1 ' Control Button
    RghtButton var PORTA.2
    second var byte
    minute var byte
    hour var byte
    tock var byte
    PAUSE 1000 ' Allow power to stabilize on power-up
    GOSUB Blink_1200 ' Blink 12:00 time on entry
    Tick:
    gosub Read_1307 ' Read the time from the DS1307 Clock
    tock = second // 2 ' Get the Mod of second
    If tock = 0 then
    High PORTB.0 ' Turn on LED connected to PORTB.0
    debug "P",12,"~" ' Turn on colon
    Low PORTB.0 ' Turn off LED connected to PORTB.0
    debug "P",0,"~" ' Turn off colon
    ' Display time
    DEBUG "D",hour DIG 1,hour DIG 0,minute DIG 1, minute DIG 0
    Goto Tick ' Go back to Tick
    Read_1307:
    ' Read time Seconds,Minutes,Hours
    I2CREAD SDA,SCL,$D0,$00,[second,minute,hour] ' Read time from DS1307
    Write_1307:
    ' Set time to 12:00
    I2CWRITE SDA,SCL,$D0,$00,[$00,$1E,$C,$01,$01,$01,$00,$90] ' Write to DS1307
    RETURN ' Sec Min Hr Day D M Y Control
    Blink_1200:
    ' Write 12:00 on display
    DEBUG "D",1,2,0,0
    debug "C","~" ' Clear Display
    if LeftButton = 1 then
    gosub Write_1307
    goto Tick
    Goto Blink_1200
    I was going to rewrite everything for you, but then you wouldn't learn anything and we'd be here for months.
    Look at your code as you've written it. Look at it as a bunch of blocks of code instead of lines. Look at the structure of it. Follow your code thru. You'll see that it never gets a chance to loop around and around the way you probably want it to. I see a couple of GoSub's without RETURNs (very bad idea!). # of Gosubs = # of Returns.
    You've got the jist of it, the idea is ok. The reading and writing of the 1307 probably won't work, don't know...but that's beside the point at the moment. Try putting all of your subroutines at either the start of the program and jump over them to a 'main loop'.
    While your at it, do a search here on the site for DS1307 and you'll find a load of hits for program ideas.
    Hi Jeff,
    Give this a shot. I've tested it on a 16F627A, and it works fine.
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_MODE 0 ' 1 = inverted, 0 = true
    TRISA = %11111111
    second var byte
    minute var byte
    hour var byte
    tock var byte
    CMCON = 7 ' all digital - comparators disabled
    Tick:
        If tock = 0 then
        DEBUG "P",12,"~" ' Turn on colon
        DEBUG "P",0,"~" ' Turn off colon
        ' Display time
        PAUSE 1000
    Read_1307:
    Write_1307:
     ' Set time to 12:00
        I2CWRITE SDA,SCL,$D0,$00,[$00,$00,$0C,$01,$01,$01,$00,$90] ' Write to DS1307
    Blink_1200:
        DEBUG "D",1,2,0,0
        DEBUG "C","~" ' Clear Display
        gosub Write_1307
        'goto Tick
        Goto Blink_1200
    You can compare this to your original to see where I made the few changes.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Apr 2007
    Thumbs up That works
    Bruce:
    Thanks for your help. Those changes solved it. Which line was responsible for keeping it from working?
    OR
    The RETURN in the IF THEN block?
    Thanks again for your help!
    Jeff
    Quote Originally Posted by JeffnDana View Post
    Bruce:
    OR
    Jeff
    That is why Skimask did not do a re-write for you, you did not learn or listen to him.
    Blocks of code, GOSUBS/RETURNS,etc and CMCON.
    Print you code and the code Bruce did, study side by side - line by line.
    Your first try was not far off for a first timer pun intended
    Hi Jeff,
    CMCON was the show stopper for the switch input, but GOSUB's without the
    RETURN (as already mentioned) was another problem.
    You might also want to include a conversion routine just after your GOSUB
    Read_1307 to convert before displaying the results.
    Something like this;
    Temp var byte ' for conversion routine
    Then just after GOSUB Read_1307 insert GOSUB Convert.
    Here's Convert:
    Convert:
        IF hour >=$10 THEN
           Temp = (hour>>4)&$0F
           Temp = (temp*10)+(hour&$0F)
           hour=temp
        IF minute >=$10 THEN
           Temp = (minute>>4)&$0F
           Temp = (temp*10)+(minute&$0F)
           minute=temp
        IF second >=$10 THEN
           Temp = (second>>4)&$0F
           Temp = (temp*10)+(second&$0F)
           second=temp
    I just happened to be working on a few routines for the SLED-C4, and figured
    I would give you a boost.
    And, yes, you should also get cozy with the 16F62xA datasheet so you'll
    know what each I/O-pin can do & what you'll need to write to certain
    registers to make things work right...;o}
    -Bruce
    tech at rentron.com
  1. PortA Doesn't Work
    Last Post: - 8th September 2015, 19:41
  2. Newbie - 16F628A and switch latching
    Last Post: - 19th May 2006, 03:35
  3. Why doesn't my code for 18f452 work on 18f252?
    By senojlr in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2005, 03:42
  4. Switch Sequence
    Last Post: - 13th February 2005, 21:36
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
