Functions in Pic Basic Pro
Results 1 to 7 of 7
    Default Passing variables to subroutines
    Not entirely sure I see your problem. You can easily pass values to a subroutine and the subroutine can return new values for the program to act on.
    For example, I can set up an array of characters to send and then call a custom built TRANSMIT subroutine. That subroutine might have error checking and require a handshake or acknowledgement from the distant receiver. The results of that acknowledgement or other parameters like time of transmission, etc are stored in variables that are accessible to the main program once the subroutines finishes.
    Likewise I can call a RECEIVE subroutine that gets a group of characters and stores them in an array for the main program to use.
    If you need speed, and you can handle assembler, then the subroutine can include blocks of assembly language by using the ASM/ENDASM instructions
    Sure you can use global variables in Subroutines,
    And you can get values returned to you from the subroutine,
    But what you can't do with PBP, is embed a call to a subroutine (function) and have the result returned into the current formula.
    I'm sure what everyone wants is to do something like this.
    Function  Val(str as String) : as WORD
    End Function
    ' And then be able to
    MyVar = 100 * Val(MyString) + 10 / 2
    Never going to happen with PBP.
    There's lots of ways to do the same thing. But the easy way? Nope!
    Apr 2007
    Thanks for the help. I was also thinking along the same line as you guys were, to just use global variables to emulate the function operation, but i wanted to make sure. I also have a question about the way to structure a program so that i can use gosub routines and global variables to emulate functions. I am currently working on a RFID entry system, and i am using a HTRC110 reader chip to communicate with the PIC and the transponders. Now to communicate with the reader chip i need to initialize a serial interface,this is the code to get that done
    SCLK VAR PORTB.0
    DIN VAR PORTB.1
    DOUT VAR PORTB.2
    LOW DIN
    LOW SCLK
    HIGH SCLK
    HIGH DIN
    LOW SCLK
    LOW DIN
    Now every time i need to send a command to the reader chip i need to send these commands first to initialize the interface and then the necessary command.Using a gousb routine i can modify it so that i can just call this code piece every time i need to use this code. My question is where in the program should i place this routine, should it be at the start of the program or towards the end. If i put it in the beginning this code will run regardless of whether it was called to be run or not. My question is how to code it so that i can optimize it so that the pic is not running code when its not beign used. Also is there a way to execute commands that start in the middle of a program. For example if i have a program that is a 100 lines, is there a way to start the program execution at line 50 instead of line 1? I know that its probably unlikely but i would like to know if there was a way.
    I have also attached my current code, so if you guys have any suggestion please let me know, and again thanks for the help
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    For your first part – when I have a large program and want to use a function-like appraoch, I do something like this.
    ' Variables for use inside functions
    temp1 var word
    temp2 var word
    temp3 var word
    ' for Divide Function
    Numerator var temp1
    Denominator var temp2
    DivAnswer var temp3
    ' for Square Function
    tobesquared var temp1
    SqrAnswer var temp2
    ' Do lots of stuff here
    Numerator = 45
    Denominator = 5
    Gosub Divide
    Serout, Portb.1, 2, (#DivAnswer)
    ' More stuff here
    tobesquared= 9
    Gosub Squared
     Serout, Portb.1, 2, (#SqrAnswer)
    ' Do more stuff
    Goto Main
    ' Divide Function
    Divide:
    DivAnswer = Numerator/Demonimator
    ' Squared Function
    Squared:
    SqrAnswer = tobesquared * tobesquared
    In this manner, I can use names that make sense but reuse the globals each time.
    For your second part try something like this:
    counter var byte
    compare var bit
    counter = 0
    GOTO Main ' jump over subroutine (to wherever I want, even line 100)
     'Init ABIC Suroutine
    INTABIC:
    LOW DIN
    LOW SCLK
    HIGH SCLK
    HIGH DIN
    LOW SCLK
    LOW DIN
    for counter = 7 to 0 step -1
    	if config_page_1.0[counter] Then
    		HIGH DIN
    		LOW DIN
    	ENdif
    	HIGH SCLK
    	LOW SCLK
    next counter
    GOSUB INITABIC
    	if config_page_3.0[counter] Then
    		HIGH DIN
    		LOW DIN
    	ENdif
    	HIGH SCLK
    	LOW SCLK
    next counter
    GOSUB INITABIC
    etc.
    GOTO Main
    Last edited by paul borgmeier; - 5th April 2007 at 00:02. Reason: minor type in code -
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 14:18
  2. I want to buy PIC BASIC PRO...
    By simransingh in forum General
    Last Post: - 30th October 2007, 18:13
  3. PIC BASIC or PIC BASIC PRO
    By kirkmans in forum USB
    Last Post: - 20th April 2007, 01:52
  4. Replies: 5
    Last Post: - 17th January 2006, 20:26
  5. How to use 93C46 Type EEPROM using PIC Basic PRo
    By in forum mel PIC BASIC Pro
    Last Post: - 1st April 2003, 05:07
