Bit set question
Results 1 to 5 of 5
    Oct 2006
    Default Bit set question
    I want to set a particular bit of a word, so I am doing it this way:
    If channel < 16 then
    control1.(channel + 1) = 1
    I want to set the (channel + 1)th bit of control1 to 1. The complier does not like this. Do you know how else I can do this?
    control1.0(channel + 1) = 1
    or
    control1.1(channel) = 1
    Oct 2006
    Thanks....so just to confirm
    This command does change the (channel + 1)th bit right and not the 0th bit of control1?
    Yes. The (channel + 1) bit.
    By putting the .0 after the variable name, it forces PBP to use it as a BIT Array, regardless of what the original variable was defined as.
    If you use .0 then it starts at bit0
    If you use .5 it starts at bit5. An index value of 0 will set bit5. An index of 4 will set bit0 in the next byte.
    Oct 2006
    Thanks a lot!
  1. Interruptus Frustratus
    Last Post: - 17th April 2009, 21:36
  2. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
