Protect the code
Results 1 to 24 of 24
    100% safe ... NO.
    The program can be retrieved. But it takes some extremely knowledgable people to do it. There are even some places that will do it for you for about $5000. The reputable ones require a statement in writing that you are the original owner of the program (but that's just for their protection, not yours).
    Some of the really old chips like 12C and some 16C are much easier, and can be done cheaper.
    Italy
    (Copy Protection in Modern Microcontrollers).
    See this link:
    http://www.cl.cam.ac.uk/~sps32/mcu_lock.html
    The latest paper on this subject:
    http://www.cl.cam.ac.uk/techreports/UCAM-CL-TR-630.html
    Semi-invasive attacks – A new approach to hardware security analysis
    Sergei P. Skorobogatov
    April 2005, 144 pages
    http://www.cl.cam.ac.uk/techreports/UCAM-CL-TR-630.pdf
    Best regards,
    Luciano
    Here's some nasty little devices that can just read the protected chips without destroying them.
    http://www.semiresearch.com/index.php?-1226852084
    http://www.semiresearch.com/index.php?-89148003
    Default Bad, really bad news.
    I thought it was almost impossible, i had read about microscopic readings of the memory and stuff like that, but this are really bad news, it even isnt that expensive!!! if you consider you could charge 5000 for one copy like DARREL already said.
    So this piece of crap can copy 877A, is it safer to move to 18F?
    A little thought... "had someone bought this thing? maybe its microcontroller is a 877A and we can copy it just to f...k them!" JAJAJA.
    Talking
    If you do not sleep at night ...
    you can also use the Writecode function , and destroy a part of the code ... if the circuit is out of its original board !!! Not too difficult to realize ...
    just a "concours Lépine" idea ...
    Jun 2007
    Default frying an IO for code protect
    I have almost finished a very complicated and time consuming project. Code protection is very important to me. But I do not feel I can trust the code protect feature in the pic. so now what ?
    What do you guys think of frying an IO and having a simple code that says if this io is low then erease the pic, that sort of thing ? the IO would have to goto no where otherwise the pepole who are trying to make a clone would try to find out what it is for. Normally an IO that is tied no where goes high, becuase of the internal pullup. but if we could only fry that part then it might be able to read low.
    The thing is the code would need to be descrete, otherwise these copy cats would see it easy.
    Omaha, Nebraska USA
    The subject of code protection came up in one of the classes I attended at Microchip's 2007 Masters Conference earlier this month.
    According to the information I received, if the CP bit is set: So far, no one has come up with a way to beat it short of a physically invasive method--microscopic examination of the die.
    Russ
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. Loop with two motor and 2 sensors
  3. Making Program Code Space your playground...
  4. F452 Code Protect
    By onur in forum mel PIC BASIC Pro
    Last Post: - 4th August 2006, 10:18
  5. Setting Code Protect and Data Protect
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 29th March 2006, 01:35
