Combine Interrupts
Results 1 to 3 of 3
    Default Combine Interrupts
    I need a little help,did some one know if I can Combine this two interrupt like here:
    INCLUDE "modedefs.bas"
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 25 ' 9600 Bauds
    DEFINE HSER_CLROERR 1
    INTCON = %11100000 ' Enable interrupts Usart and TMR0
    OPTION_REG =%00000110 'Prescaler = 128
    On INTERRUPT GoTo Main '''''Usart
    PIE1.5 = 1
    On INTERRUPT GoTo Overflow ''''''Timer0 Overflow
    PIE1.0 = 1
    Loop:
    Goto Loop
    Disable
    Resume
    Overlow:
    INTCON.2=0 '''''''''''''''''''''''Clear Overflow
    Resume
    Thanks a lot for any answer.
    Regard Pesti
    You can only have 1 ON INTERRUPT handler on a 16F.
    In that handler, you can monitor the different Flags associated with the different interrupts and then execute the appropriate routine.
    In your case, you want TMR0 and the USART, so you need to watch for TMR0IF and RCIF.
    Most people only check for the flag, but I also like to make sure the Interrupt source is Enabled too, by checking TMR0IE and RCIE. That way it will stil work according to plan when you disable/enable interrupts at random.
    For your suedo code, it might look like this...
    DEFINE HSER_BAUD  9600
    PEIE   VAR INTCON.6
    RCIE   VAR PIE1.5
    RCIF   VAR PIR1.5
    T0IE   VAR INTCON.5
    T0IF   VAR INTCON.2
    OPTION_REG = %00000110  ' Prescaler = 128, RB pull-ups on
    PEIE = 1           ' enable Peripheral interrupts
    T0IE = 1           ' enable TMR0 interrupts
    RCIE = 1           ' enable USART RX interrupts
    On INTERRUPT GoTo IntHandler
    Loop:
    Goto Loop
    Disable
    ;___________________________________
    IntHandler:
        IF RCIE and RCIF then USART_RX
        IF T0IE and T0IF then TMR0_OVR
        HIGH PORTB.0  ; indicate "Unchecked Interrupt"
    Resume
    TMR0_OVR:
        T0IF = 0  'Clear Timer0 flag
    Resume
    USART_RX:
        Dummy = RCREG ' Clear USART Flag by reading USART data
    Resume
    HTH,
    Thank you !
    Now I understand how the Interrupts are working!
    Tahnks a lot.
    Regard.
    Pesti.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Continuous Interrupts when using DT_INTS and an INCLUDE file
    Last Post: - 15th January 2010, 21:42
  3. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
