__CONFIG depreciated warning messages
Results 1 to 6 of 6
    Mar 2007
    Default __CONFIG depreciated warning messages
    I get these warnings when I compile for an 18F4431 using MASM:
    Warning[230] c:\pbp\18f4431: __CONFIG has been depreciated for the PIC18 devices. Use the directive CONFIG.
    I tried this and it went from warnig to errors. Any suggestions or comments. I searched the forums for 'depreciated' but no hits.
    thanks
    t
    Mentor, Ohio
    Smile
    Hello ttease,
    See this thread http://www.picbasic.co.uk/forum/show...3087#post13087
    This should this should help you out.
    btw: I found this by searching for Bruce's contributions through the members list.
    BobK
    Mar 2007
    Default Link is 404, Bruce who?
    Bob,
    Thanks for the reply and link but the link is 404 and I'm not sure who Bruce is. Can you spare some more details. Yes, yes, I'm new.
    thx
    t
    Apr 2006
    New Hampshire USA
    Smile the forums search engine
    Hi t,
    Wecome to the forum.
    I used the forums search engine, pasted in....
    Warning[230]
    ....and found all sorts of interesting information about....
    Warning[230]
    You will find out who Bruce is.
    -Adam-
    Mentor, Ohio
    Smile
    Hi ttease,
    Sorry about you getting the error message. Go to the Members list. It's on the same bar above as the Search button. Goto the "B's" and about the 5th or 6th page and you will see BRUCE. Look for posts that Bruce has been on. Around the 6th page about half way down is the posts regarding the deprication stuff.
    I just copied and pasted the link. Bruce is one of the "extremely knowledgeable ones" on this forum and also the owner of Reynolds Electronics. www.rentron.com.
    HTH,
    BobK
    Hi T,
    Here's a link directly to that thread; http://www.picbasic.co.uk/forum/show...3087#post13087
    You can upgrade to the latest version of PBP to get rid of this particluar
    warning message. MeLabs has changed default device header files to include
    the command line switch that disables this.
    From the PBP 2.47 18F4431.INC;
    LIST p = 18F4431, r = dec, w = -311, w = -230, f = inhx32
    The w = -230 disables this message.
    Look in your MPASM Assembler help file under Warning Messages for details.
    As I mentioned in the above thread, Microchip has now made this mandatory
    for the PIC18FXXJ parts, so it's a good idea to look into/understand this one.
    If you have a version of PBP that now supports the PIC18FXXJ parts, you'll
    notice the default device header files for these don't include the w = -230,
    and have config fuse options using the CONFIG VS __CONFIG option.
    Here's how it looks in the 18F44J10.INC file;
    LIST p = 18F44J10, r = dec, w = -311, f = inhx32
    INCLUDE "P18F44J10.INC" ; MPASM Header
    CONFIG XINST = OFF
    CONFIG FOSC = HS
    CONFIG WDTPS = 512
    A list of config options for each part can be found in your MPLAB directory in
    each 18F parts device specific .INC file.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Warning (and other Compilation Error) Messages
    Last Post: - 9th September 2009, 02:29
  2. Warning 221 after upgrade to ver 2.50a
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 29th April 2008, 06:56
  3. 12F683 RAM Warning
    By Johan in forum mel PIC BASIC Pro
    Last Post: - 18th August 2007, 11:51
  4. Micro Code Studio - Warning message
    Last Post: - 17th November 2006, 22:17
  5. CONFIG directive warning help
    By josegamez in forum mel PIC BASIC Pro
    Last Post: - 8th August 2006, 21:02
