Help with serin, serout, Manchester encoding
Results 1 to 31 of 31
    Mar 2007
    I'm using a 4 MHz crystal oscillator. I'm sure that the stuff is encoding and decoding correctly since it is written correctly in my EEPROM and my logic works most of the time. It seems like my program is executing straight down and is going through incorrect if loops sometimes. For example, when I enter 0101 but somehow my microcontroller will write in memory location 3 and 4. It is only supposed to write in memory location 4. Is there anyway to clear the memory before I start my program? Also, is there anyway that I can prevent it from executing through other if loops? I have attached my new code below.
    Receiver code:
    Include "Modedefs.bas"
    s var byte : B0 var bit : B1 var bit : 's is byte to be encoded, B0 and B1 is byte
    counter var byte : cnt55 var byte: 'counter is byte and cnt55 is byte
    encoded1 var byte : action var byte : alert var byte : action2 var byte: B0=1 : B1=1
    'encoded1 word sized variable that holds encoded byte v, alert variable, action variable, B0 and B1 hardwired address
    s=0: encoded1=0
    maina:
    cnt55 = 0 'counter for $55 is zero
    waitfor55:
    serin PORTB.0, n2400, encoded1 'take in data at pin 0 and place in encoded1
    if encoded1 = $55 then
    cnt55 = cnt55 + 1 '$55 read, increase cnt55 by 1
    if cnt55 = 4 then goto waitforaa 'if $55 occurs 4 times in a row check for $aa
    goto maina 'if not $55, reset counter at main and restart
    goto waitfor55
    waitforaa:
    if encoded1 <> $aa then goto maina 'restart, incorrect leader bit
    serin PORTB.0, n2400, encoded1 : 'serout PORTB.4, n2400, [encoded1] take in from pin 0 to encoded 1 output to pin 3 contens in encoded1
    write 0,encoded1
    High 7
    Pause 2000
    Low 7
    'Decoding
    For counter=0 to 3:s.0[counter]=encoded1.0[counter*2]:Next counter
    'serout PORTB.3, n2400, [s] 'Ouptut decoded message
    write 1, s
    High 6
    Pause 2000
    Low 6
    if ((s.3==0) && (s.2==1)) then 'Check if address matches
    goto L3
    write 2,s
    High 2
    Pause 2000
    Low 2
    L3:
    if ((s.1==0) && (s.0==0)) then 'if the address Tracking then
    action = s: action.1=1'set the third bit to 1 and send it back
    alert = 0: 'serout PORTB.1, n2400, [action1] 'output to pin 1 value
    write 3, action
    High 1
    Pause 2000
    Low 1
    if ((s.1==0) && (s.0==1)) then 'If the address Tracking and Finding then
    action2 = s:action2.1=1 'set the third bit to 1 and send back
    alert=1: 'serout PORTB.4, n2400, [action2]: 'output to pin 1 value i
    write 4, action2
    High 4
    Pause 2000
    Low 4
    Quote Originally Posted by oneohthree View Post
    Well, yes, it is going to execute straight down (as it's laid out here in the forums). Read thru it. How is it supposed to NOT execute straight down? There's no jumps back to the main loop or anything anywhere (except for where the serial data is received).
    Mar 2007
    For my code, I use If ((s.3==0) && (s.2==1)) then
    goto L3
    Is it better to place L3 before the if statement or after it?
    Is it a good idea to do If ((s.3==0) && (s.2==1)) or should I separate the if statement?
    goto L3
    If ( s.3 = 0 ) and ( s.2 = 1 ) is fine. (In practice I don't use ==, I always use =, same thing for the &&, I always use 'AND', easier to read)
    If you think the L3 before the if will work better, then try it.
    Last Post: - 8th March 2010, 20:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 16:46
  3. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  4. Advice-scrutiny for my serial controller
    Last Post: - 13th December 2008, 17:11
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
