Quote Originally Posted by oneohthree View Post
I think I figured it out I was reading the bits the wrong way. For example, when I send 2345 I originally assumed that s.0=2, s.1=3, s.2=4 and s.3=5 but it was in fact the other way. My code now works 90% of the time, occasionally my program will jump to if statements that it is not supposed to go to and write data there.
If you're using the RF link, try the straight serial connection first. You can keep the encoding in there.
If it still doesn't work, check your oscillators. If you're using the internal oscillators, probably should go to a crystal.
