Are you sure that you are receiving at the RX the same thing you are sending at the TX?
'Decoding
For counter = 0 to 3 : s.0[counter] = encoded1.0[counter * 2 + 1] : Next counter
Try that and see what happens...for grins...
'Decoding
I think I figured it out I was reading the bits the wrong way. For example, when I send 2345 I originally assumed that s.0=2, s.1=3, s.2=4 and s.3=5 but it was in fact the other way. My code now works 90% of the time, occasionally my program will jump to if statements that it is not supposed to go to and write data there.
I'm using a 4 MHz crystal oscillator. I'm sure that the stuff is encoding and decoding correctly since it is written correctly in my EEPROM and my logic works most of the time. It seems like my program is executing straight down and is going through incorrect if loops sometimes. For example, when I enter 0101 but somehow my microcontroller will write in memory location 3 and 4. It is only supposed to write in memory location 4. Is there anyway to clear the memory before I start my program? Also, is there anyway that I can prevent it from executing through other if loops? I have attached my new code below.
Receiver code:
Include "Modedefs.bas"
s var byte : B0 var bit : B1 var bit : 's is byte to be encoded, B0 and B1 is byte
counter var byte : cnt55 var byte: 'counter is byte and cnt55 is byte
encoded1 var byte : action var byte : alert var byte : action2 var byte: B0=1 : B1=1
'encoded1 word sized variable that holds encoded byte v, alert variable, action variable, B0 and B1 hardwired address
s=0: encoded1=0
maina:
cnt55 = 0 'counter for $55 is zero
waitfor55:
serin PORTB.0, n2400, encoded1 'take in data at pin 0 and place in encoded1
if encoded1 = $55 then
cnt55 = cnt55 + 1 '$55 read, increase cnt55 by 1
if cnt55 = 4 then goto waitforaa 'if $55 occurs 4 times in a row check for $aa
goto maina 'if not $55, reset counter at main and restart
goto waitfor55
waitforaa:
if encoded1 <> $aa then goto maina 'restart, incorrect leader bit
serin PORTB.0, n2400, encoded1 : 'serout PORTB.4, n2400, [encoded1] take in from pin 0 to encoded 1 output to pin 3 contens in encoded1
write 0,encoded1
High 7
Pause 2000
Low 7
'Decoding
For counter=0 to 3:s.0[counter]=encoded1.0[counter*2]:Next counter
'serout PORTB.3, n2400, [s] 'Ouptut decoded message
write 1, s
High 6
Pause 2000
Low 6
if ((s.3==0) && (s.2==1)) then 'Check if address matches
goto L3
write 2,s
High 2
Pause 2000
Low 2
L3:
if ((s.1==0) && (s.0==0)) then 'if the address Tracking then
action = s: action.1=1'set the third bit to 1 and send it back
alert = 0: 'serout PORTB.1, n2400, [action1] 'output to pin 1 value
write 3, action
High 1
Pause 2000
Low 1
if ((s.1==0) && (s.0==1)) then 'If the address Tracking and Finding then
action2 = s:action2.1=1 'set the third bit to 1 and send back
alert=1: 'serout PORTB.4, n2400, [action2]: 'output to pin 1 value i
write 4, action2
High 4
Pause 2000
Low 4
For my code, I use If ((s.3==0) && (s.2==1)) then
goto L3
Is it better to place L3 before the if statement or after it?
Is it a good idea to do If ((s.3==0) && (s.2==1)) or should I separate the if statement?
