Help with serin, serout, Manchester encoding
Results 1 to 31 of 31
    Cool
    Quote Originally Posted by oneohthree View Post
    I got serin to partially work on the receiver side (with and without wireless). The problem I am having now is it seems like after I decode it I have about 4 extra bits at the end of my decoded sequence. How do I get rid of it?
    And we're supposed to be able to help you fix that because we can see what your code looks like, right?
    Mar 2007
    Here is my revised code:
    'Transmitter Code
    Include "Modedefs.bas"
    v var word 'v is a byte to be encoded
    counter var byte 'counter is a byte
    encoded var word 'encoded is a word sized variable that holds the encoded byte v
    'Code to be transmitted
    v = %1101 '1101 in Binary
    'Manchester Encoding
    For counter = 0 to 3 'number of bits to be encoded (4 bits)
    If v.0[counter]=0 Then encoded.0[counter*2]=0 'if it is a zero make the first bit 0 encoded.0[counter*2+1]=1 'make the second bit 1
    Else
    encoded.0[counter*2]=1 'if it is a 1 make the first bit 1
    encoded.0[counter*2+1]=0 'make the second bit 0
    EndIf
    Next counter
    'Serial Out
    serout PORTB.0, t2400, [$55,$55, $55, $aa, encoded] 'serial out in pin 0 using non-inverted 2400 bps to encoded
    'Receiver Code
    s var word 's is a byte to be encoded
    B0 var byte 'B0 is a byte
    B1 var byte 'B1 is a byte
    counter var byte
    encoded1 var word 'encoded1 word sized variable that holds the encoded byte v
    action var byte 'action variable
    alert var byte 'alert variable
    B0=1 'hardwired address
    B1=1 'hardwired address
    'Decoding
    waitfor55:
    serin PORTB.0, t2400, encoded1: if encoded1 = $55 then goto waitfor55
    waitforaa:
    serin PORTB.0, t2400, encoded1: if encoded1 = $aa then goto waitforaa
    serin PORTB.0, t2400, encoded1 'serial in to pin 0, a non-inverting 2400 bps to encoded1
    serout PORTB.3, t2400, [encoded1]
    loop:
    s.0[counter]=encoded1.0[counter*2] 'proceed through counter and copy encoded1 to s
    Next counter
    goto loop
    serout PORTB.3, t2400, [s] 'serial out to pin 3, a non-inverting 2400 bps, to s
    'Tracking code
    If (s.2==0) & (s.3==0) Then 'If the code matches 00 then it is in the tracking mode
    If (s.0==B0) & (s.1==B1) Then 'If the address matches then
    s.2=1 'Change the third bit to 1
    action = s.2 'action becomes 1
    alert = 0 'alert becomes 0
    serout PORTB.1, t2400, [s] 'Send the changed word back, serial out to pin 1, a non-inverting 2400 bps, to s
    Else
    s.2=0 'Since the addresses does not match do not change anything
    action = s.2 'action becomes 0
    Endif
    Endif
    'Tracking and Finding code
    If (s.2==0) & (s.3==1) Then 'If the code matches 01 then it is in the tracking and finding mode
    action=s.2 'action becomes 1
    alert=1 'alert becomes 1
    High 2
    Else
    s.2=0 'Since the address does not match do not change anything
    action=s.2 ;action becomes 0 and alert is also 0
    alert=0
    serout PORTB.1, t2400, [s] 'Send te changed word back, serial out to pin 1, a non-inverting 2400 bps, to s
    Endif
    Endif
    [QUOTE=oneohthree;35632]Here is my revised code:
    That code is entirely TOO complicated for the job you are trying to get done...
    Hang tight for a bit...
    'Transmitter Code
    v var byte : counter var byte : encoded var byte : v = %1101
    Else
    encoded.0[counter*2]=1 : encoded.0[counter*2+1]=0
    EndIf
    Next counter : serout PORTB.0, t2400, [ $55 , $55 , $55 , $aa , encoded ]
    'Receiver Code
    s var byte : B0 var byte : B1 var byte : counter var byte : cnt55 var byte
    encoded1 var byte : action var byte : alert var byte : B0=1 : B1=1
    cnt55 = 0
    waitfor55:
    cnt55 = cnt55 + 1 'got $55, inc cnt55 by 1
    if cnt55 = 3 then goto waitforaa 'if we got 3 in a row check for $aa
    goto main 'if not $55, reset counter at main and restart
    goto waitfor55
    waitforaa:
    if encoded1 <> $aa then goto main 'restart, didn't get right leader
    serin PORTB.0, t2400, encoded1 : serout PORTB.3, t2400, [encoded1]
    For counter=0 to 3:s.0[counter]=encoded1.0[counter*2]:Next counter
    'Tracking code
    s.2=1:action = s.2:alert = 0:serout PORTB.1, t2400, [s]
    Else
    s.2=0:action = s.2:alert = 0:serout PORTB.1, t2400, [s]
    Endif
    Endif
    s.2=1:action=s.2:alert=1:serout PORTB.1, t2400, [s]:High 2
    Else
    s.2=0:action=s.2:alert=0:serout PORTB.1, t2400, [s]
    Endif
    Endif
    Your logic for getting the leader bytes and stuff was messed up, so I rewrote it a bit.
    But I still think this is entirely too convoluted.
    What exactly are you trying to do? Because this seems a bit goofy to me, all this bit manipulation and such. Even though it's a short program, it just seems to me like you'll get yourself stuck in future trying to figure out what you were trying to do in the first place.
    Mar 2007
    This is a part of the 2 way paging system that I am doing for a project. Basically what I am trying to do is take 4 bits from the transmitter that I get at the receiver end and do some operations on it. I am assuming that the first two bits are the address and the last two bits are the mode. There are two modes tracking and finding. In each case, I am first checking the last two bits to see which mode it is. After I do that, I am checking if the first two bits of address matches. If the address matches, it will change the third bit (kind of like an acknowledgement) and output the result somewhere. If it does not match it will not change the code and output it back. In the find mode, it does the same thing except it will make a pin high in order to set off an alert like a LED. Is this making any sense?
    Ok, that makes a bit more sense....
    A bit (pun intended) simpler, maybe????......
    Take a sent byte...invert it and send it back as some sort of acknowledge.
    For instance: (using 4 bits, $5, $A, $0, $F, are already taken, so can't use those)
    Send $1, return $E, acknowledged
    Send $2, return $D, and so on...
    Anything else returned would be 'not' acknowledged...
    Leaves you with $1,2,3,4,6,7 for send codes ($E,D,C,B,9,8 for returned codes).... if 6 codes is enough for you...
    That way you could set the 'address' for each pager/receiver with 3 DIP switches (with 2 unused combo's)...
    Mar 2007
    Would it matter if I used t2400 or n2400 in my code for serin/serout? I used n2400 in my code and everything is encoding and decoding correctly. I know this because the number at the receiver checks when I write the result into EEPROM and convert the hexadecimal to binary. Also, it seems like the receiver code does not go to the if statements at the end. For example, if I receive 1100 it serout something to pin 1. When I put a LED at pin 1 I don't see anything. Is there anyway I can fix it? Would I have to change my decoded message from hexadecimal to binary in order to allow me to manipulate the bits?
    'Transmitter Code
    'Transmitter Code
    v var byte : counter var byte : encoded var byte : v = %1100
    'Manchester encoding
    encoded.0[counter*2]=0 : encoded.0[counter*2+1]=1 'If it is a zero make the first bit 0 and second bit 1
    Else
    encoded.0[counter*2]=1 : encoded.0[counter*2+1]=0 'If not then make first bit 1 and second bit 0
    EndIf
    Next counter : serout PORTB.0, n2400, [ $55 , $55 ,$aa , encoded ] 'send out code
    write 0, encoded
    High 1
    Pause 1000
    Low 1
    'Receiver Code
    s var byte : B0 var byte : B1 var byte : 's is byte to be encoded, B0 and B1 is byte
    counter var byte : cnt55 var byte: 'counter is byte and cnt55 is byte
    'encoded1 word sized variable that holds encoded byte v, alert variable, action variable, B0 and B1 hardwired address
    s=0: encoded1=0
    cnt55 = 0 'counter for $55 is zero
    waitfor55:
    serin PORTB.0, t2400, encoded1 'take in data at pin 0 and place in encoded1
    cnt55 = cnt55 + 1 '$55 read, increase cnt55 by 1
    if cnt55 = 2 then goto waitforaa 'if $55 occurs 3 times in a row check for $aa
    goto waitfor55
    waitforaa:
    serin PORTB.0, n2400, encoded1
    if encoded1 <> $aa then goto main 'restart, incorrect leader bit
    serin PORTB.0, n2400, encoded1 : serout PORTB.4, n2400, [encoded1] 'take in from pin 0 to encoded 1 output to pin 3 contens in encoded1
    write 0,encoded1
    High 7
    Pause 10000
    Low 7
    'Decoding
    serout PORTB.3, n2400, [s] 'Ouptut decoded message
    write 1, s
    High 6
    Pause 10000
    Low 6
    'Tracking code
    If (s.2==0) & (s.3==0) Then 'if the code matches 00
    If (s.0==B0) & (s.1==B1) Then 'if the address matches then
    s.2=1: action = s.2: 'set the third bit to 1 and send it back
    alert = 0:
    serout PORTB.1, n2400, [s] 'output to pin 1 value in s
    Else
    s.2=0: action = s.2: 'do not change anything and send back
    alert = 0:
    serout PORTB.2, n2400, [s] 'output to pin 1 value in s
    Endif
    Endif
    If (s.2==0) & (s.3==1) Then 'if code matches 01 then
    s.2=1: action=s.2: 'set the third bit to 1 and send back
    alert=1:
    serout PORTB.6, n2400, [s]: 'output to pin 1 value in s
    High 2 'set alert to 1 and make pin 2 high.
    Else
    s.2=0: action=s.2: 'do not change anything and send back
    alert=0:
    serout PORTB.5, n2400, [s] 'output to pin 1 value in s
    Endif
    Endif
    'Transmitter Code
    Else
    EndIf
    Next counter : serout PORTB.0, n2400, [ $55 , $55 , $55 , $55 , $55 , $55 ,$aa , encoded ] 'send out code
    write 0, encoded
    High 1
    Pause 1000
    Low 1
    'Receiver Code
    counter var byte : cnt55 var byte : cntaa var byte 'counter is byte and cnt55 is byte
    s=0: encoded1=0
    cnt55 = 0 : cntaa = 0 'counter for $55 & $aa is zero
    waitfor55:
    if cnt55 > 3 then goto waitforaa 'if $55 occurs more than 3 times in a row check for $aa
    goto waitfor55
    waitforaa:
    cntaa = cntaa + 1
    if cntaa > 5 then goto main 'restart, incorrect leader bit
    write 0,encoded1
    High 7
    Pause 10000
    Low 7
    'Decoding
    write 1, s
    High 6
    Pause 10000
    Low 6
    'Tracking code
    alert = 0:
    Else
    alert = 0:
    Endif
    Endif
    alert=1:
    Else
    alert=0:
    Endif
    Endif
    Try that out. Send more $55's for the leader (more time for RX to sync up), wait for at least 3 of them. When you get 3, start watching for an $AA. If you don't get an $AA within 5 bytes, restart the process.
    As far as changing hex to binary...PBP doesn't care one way or the other. You are working with a byte. PBP can work on bytes, bits, hex, binary, doesn't matter. Just a matter of looking up the right math operator and using it.
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
  3. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  4. Advice-scrutiny for my serial controller
    Last Post: - 13th December 2008, 18:11
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
