Simple RF receivers need a preamble to condition the data slicer. I have had great success with low power Rf comms by using a pseudo Manchester strategy.
Manchester code is usually recommended because it guarantees at least one transition per bit so a long run of 000 or 111 can be successfully decoded.
The following also works. Assuming a 4 bit nibble is to be sent, build a character of start bit, 8 data bits and one or preferably 2 or more stop bits. Use Char_Pacing to get extra stop bits. 8 bit bytes need to be broken into two halves before sending. A checksum on any data block is highly recommended.
Byte bit 0 is nibble bit 0
Byte bit 1 is inverted nibble bit 0
Byte bit 2 is nibble bit 1
Byte bit 3 is inverted nibble bit 1
Byte bit 4 is nibble bit2
Byte bit 5 is inverted nibble bit 2
Byte bit 6 is nibble bit 3
Byte bit 7 is inverted nibble bit 3
Now transmit this character many times - say 32 or more. The first few characters act as the preamble and the data stream is very nearly 50:50 duty cycle so the receiver data slicer is happy. Depending on link characteristics you may be able to cut the transmitted data down to 16 or even less repetitions.
Perform tests on the received character stream to make sure you receive it, say, at least 3 consecutive times, where the characters are identical to each other AND the data structure of bit/inverted-bit is obeyed. Activating parity can also give you an extra check.
I have used this with expensive 154 MHz transceivers and cheap 315 and 433 MHz Tx/Rx modules with great success.
HTH
Brian
