Help with serin, serout, Manchester encoding
Results 1 to 31 of 31
    Quote Originally Posted by oneohthree View Post
    v = 1010
    For one thing, sending 1010 isn't going to work. 1010 is one thousand and ten, not 10 or $A). You probably want v = %1010.
    Mar 2007
    Also, I tested my transmitter and receiver with the microcontrollers. I was able to transmit the 1101 sequence from the transmitter to the receiver. I got the encoded version of the 1101 sequence. But, the microcontroller on the receiver end the serin command does not work for the microcontroller. When I look at the pins where I have serout on I don't see any signal. Did I do something incorrect?
    Question
    What? Doesn't make any sense...
    Mar 2007
    I don't know what is wrong either. Somehow the serin command isnt taking the data that I send in from the receiver. I check the output at pin 1 and pin 3 using a logic analyzer and I get nothing. Is there something wrong with my receiver code. Also, should I send data in inverted (n2400) or non-inverted (t2400)?
    No, I meant your sentence didn't make any sense...
    Mar 2007
    Do you have any suggestion on how I can get my serin command to work correctly?
    Yes, READ the WHOLE 'Serin SerOut Problem' thread, not to mention a half a dozen other PIC-PIC communication threads in the 'Serial' section of the forum, just like I've suggested in the other thread and more than once. And start simple and build up. You're still using the RF modules, but I don't see anything that says you're sure it all works without the RF modules. I don't see anything that says you're sure the whole thing works just between the 2 PIC's, a couple of buttons and a couple of LEDs.
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
  3. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  4. Advice-scrutiny for my serial controller
    Last Post: - 13th December 2008, 18:11
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
