serial communication between CMUcam and PIC 16F877
Results 1 to 6 of 6
    Mar 2007
    Default serial communication between CMUcam and PIC 16F877
    hello...i have a problem to interface CMUcam and PIC 16F877...can anybody give the example coding to initialize Tx and Rx in PIC 16F877???...i want to make a serial communication between CMUcam and PIC 16F877...plzzz
    I could give you the coding but I would not explain it as well as the PIC BASIC MANUAL does.
    The three options are:
    SERIN/OUT
    SERIN2/SEROUT2
    HSERIN/OUT
    Quote Originally Posted by gengkeys View Post
    Have you tried the green manual, maybe the PIC datasheets, maybe a search on this site for serial code, maybe anything at all?
    Mar 2007
    i've tried that ways but still have a problem...i still can't communicate CMUcam with the PIC...
    define osc 20
    include "modedefs.bas"
    serout portc.6,84,["L1 1",CR]
    serin portc.7,84,[(":")]
    debug "LED on ACK:received OK",CR
    serout portc.6,84,["L1 2",CR]
    debug "LED off ACK:received OK",CR
    this coding has no error but it's not working...can you comment why it happen???...
    I do not have my GREEN BOOK with me but if I remember correctly MODE 84 is used with SERIN2/SEROUT2, not SERIN/SEROUT.
    Also, how do you know the baud,parity,inverted or true ,driven or open,of your CMUcam.
    Fix the MODE problem and try playing with parity,inverted or true ,driven or open.
    define osc 20
    serout portc.6,<font color=red>84,</font color>,["L1 2",CR]
    84 is a serout2 and serin2 command for 9600 baud not serin serout ( at least I do not see where it is supported) the CMUCam2 manual says to set communications to 115,200 , 8, 1, N. And to add \n to a received \r. See page 12, the old version says the same. So you might think good thoughts about using HSERIN. Here are the numbers fresh off mister_e's calculator:
    RCSTA = $90 ' Enable serial port & continuous receive
    TXSTA = $24 ' Enable transmit, BRGH = 1
    SPBRG = 10  ' 115200 Baud @ -1.36%
    DEFINE HSER_SPBRG 10  ' 115200 Baud @ -1.36%
