electrical problem adcin
Results 1 to 7 of 7
    Red face electrical problem adcin
    trying to read a high resistance variable
    var resistor is connected to ground and pic using adcin
    reading with a voltmeter connected to + and pic pin is in millivolts can't seem to get the pic to display
    help?
    Do you have some code. A schematic or better description of the "var resistor" or do you mean potentiometer as a voltage divider would help.
    Wink Datasheet !!!
    High resistance mean a closer look to the A/D section of the Pic datasheet ...
    Cool update
    code is very simple and i am getting reading from pic so hookup is ok
    think the problem is the resistance is so great might need a amp but hate to go through this two wire resistance is connected to ground and pin of pic does flucatate on voltmeter as expected again readings are in millivolts
    just dont seem to get pic to respond dont know what range of resistance
    or voltage
    hook up is straight foward 2 wire device one wire to ground (vss ) other to pic using adcin command
    Well if you think the resistance is to high, test with something else. Fixed resistor for testing?
    What about the reference voltage?
    Apr 2006
    New Hampshire USA
    Smile try this
    Jack,
    Quote Originally Posted by jcleaver View Post
    If you put an external voltmeter between ground (Vss) and the a/d input to the PIC, what do you read?
    -Adam-
    or voltage
    If the code is very simple, then post it.
    If the schematic is equally as simple, then post it.
    Maybe then, you'll learn something, and then you won't have to ask so many questions later.
  1. ADC or ADCIN "bias" problem?
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 26th February 2010, 19:39
  2. ADCIN Problem
    By JavPar in forum General
    Last Post: - 20th January 2009, 03:36
  3. Electrical noise problem with PIC 16f84
    By Snap in forum General
    Last Post: - 26th September 2007, 09:36
  4. adcin problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 17:47
  5. weird 12F629/675 problem
    Last Post: - 7th October 2004, 01:08
