PIC12F629 - OSCCAL LOST in combat
Results 1 to 3 of 3
    Feb 2007
    Sao Paulo - Brazil
    Default PIC12F629 - OSCCAL LOST in combat
    I'm accidentally overwrite the OSCCAL value, how can I restore this value to the PIC?
    I've tried to rewrite using ICPROG, assigning the value in the last position but without success until now.
    Tks in advance.
    malc-c's Avatar
    malc-c Guest
    It is possible to regenerate the OSCAL value. Some Programmers (PicKIT1 for example) has the ability. It may be possible using the software you have by reading one of the values (the last set in the code I think). - Try searching the forum, I'm sure the subject has been covered before.
    SWITZERLAND (french speaking)
    Default Try WINPIC
    You can try WINPIC.
    It will restore the default OSCCAL value for you or you can set it as you like in the HEX editor.
    http://freenet-homepage.de/dl4yhf/winpicpr.html
    Roger
  1. How to Reset Osccal Value
    By greensasquatch in forum mel PIC BASIC Pro
    Last Post: - 1st September 2008, 03:11
  2. Lost your OSCCAL Value ???
    By Acetronics2 in forum Documentation
    Last Post: - 27th November 2007, 18:11
  3. 12f509 and OSCCAL
    By mwhatley in forum mel PIC BASIC Pro
    Last Post: - 20th October 2007, 01:35
  4. Problem DEFINE OSCCAL and PBP 2.46
    By David in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2005, 17:19
  5. PIC12F629, useing all I/O pins
    By Jcee324 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2004, 11:05
