Free Project - 245 LED Display
Results 1 to 40 of 222
    Aug 2008
    Default DOT-MATRIX display
    Don't ask for much do ya...
    What is your skill set?
    Which PIC do you want to use?
    What sort of hardware would you like to use?
    What kind of wireless transmission protocol are you planning on using?
    Lost yet?
    Try eBay...
    What i want is use two microcontroller(MCU) to build this project. One MCU is connect to PC keyboard and transmitter(using RF or IR to transmit the data).Another MCU connect to receiver(can be IR or RF circuit) and dot matrix. I found one similar project but i cant found the datesheet for the MCU used in this project. I also don't understand the code.
    Quote Originally Posted by yupng View Post
    And didn't answer ANY of the previous questions...
    Aug 2008
    i still doing the research for this project. So i not confirm what hardware are require for this project. I hope anyone has this similar project can post it to me. Actually my project topic is <Wireless Announcement Board>.
    Any information that related to this project also can post to me.
    Thanks.......
    Thanks.......
    I'd doubt anybody can help you until you help yourself.
    Until then, sounds like you might want to use something prebuilt:
    http://www.sparkfun.com/commerce/pro...roducts_id=760
    Aug 2008
    I had done this project before but not with wireless. I use RS232 port sent the data from pc to dot-matrix display module. Now, i need to improve it to be wireless.
    The problem is :
    How i send out the data via wireless.
    How to translate the receive data and display it on dot-matrix display module.
    Anyway........thanks for your reply.
    Thanks.......
    You can use radio modules like these(take your pick)
    http://www.rentron.com/PicBasic/RemoteControl.htm
    to send serial data.
    Aug 2008
    Anyone can help me do a "wireless announcement board" using dot-matrix.
    The data(text) is send out from keyboard via wireless to dot-matrix display.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  3. Replies: 2
    Last Post: - 14th July 2008, 22:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 00:07
  5. LCD will not start
